1. Heyye's Avatar
    Which one do you recommend (camera, battery, screen, cpu vs)? But for me the most important is the camera performance. Please suggest one of them. I will open this thread both Huawei and LG forums. If this is forbidden, please remove one of them. Thank you in advance. Sorry for my bad english.
    06-29-2018 10:13 AM
  2. Ry's Avatar
    What carrier?
    07-02-2018 09:15 PM
  3. andrew_ackley's Avatar
    mate 10 or p20 pro definitely
    07-03-2018 09:50 PM
  4. snowmutt's Avatar
    Straight up, the "V" series are multi-media beasts. Wife will own no other phone line. She runs a craft business (not really profitable, but breaks even and she is happy so.) She swears by them.
    LG has gotten a ton of criticisms, but we have had nothing but good luck with them. I can't say a bad word. You may not go wrong with either, though I am sure a Mate 10 Pro could be gotten for a tad cheaper.
    07-13-2018 02:50 AM
  5. OLD_HATCH's Avatar
    LG V20 here, Ask me about updates...
    Think this will be my last LG phone. First phone with Android 7.0 but have been in that since release. My wife's Huawei Mate 9 has had security updates every 3 months or so and upgraded to 8.0 with Treble support 6 months ago.
    07-14-2018 10:14 PM
  6. veg_biryani's Avatar
    Nooooo p20, the dreaded notch.
    09-05-2018 07:16 AM
  1. change notification ringtone on lg g4
    By Android Central Question in forum LG G4
    Last Post: 06-30-2018, 05:08 AM
  2. Replies: 1
    Last Post: 06-29-2018, 02:08 PM
  3. should Pixels be visible on my LG G7?
    By Mhousley37 in forum LG G7 ThinQ
    Last Post: 06-29-2018, 10:51 AM
  4. LG K30 replacement screen
    Last Post: 06-29-2018, 06:54 AM
