A Android Central Question May 25, 2019 #1 I need to get the notification log for my Huawei Mate 10 Pro but actually it doesn't appear in the widget
Rukbat Retired Moderator Feb 12, 2012 44,529 26 0 Visit site May 25, 2019 #2 Did you select the widget, then select Notification log? Then back out to the home screen and tap the Notification log icon?
