    I need to get the notification log for my Huawei Mate 10 Pro but actually it doesn't appear in the widget
    05-25-2019 04:56 AM
  2. Rukbat's Avatar
    Did you select the widget, then select Notification log? Then back out to the home screen and tap the Notification log icon?
    05-25-2019 04:13 PM
  1. Searching for GPS
    Last Post: 07-03-2019, 04:03 AM
  2. Visual Voicemail Notifications
    By hannsoft in forum Google Pixel & Pixel XL
    Last Post: 06-05-2019, 01:59 PM
  3. android 9.0 - now no mobile data
    By sallybrown1969 in forum Ask a Question
    Last Post: 05-25-2019, 10:11 PM
  4. Font in Android
    By PeterPkp123 in forum Ask a Question
    Last Post: 05-25-2019, 04:14 AM
  5. How to manage notifications that take you out of apps (e.g. calls)
    Last Post: 05-24-2019, 09:16 PM
