1. VespaTS's Avatar
    Hi,
    unfortunately I had a water incident. Despite being officially IP68 my Mate 20 Pro did not like it.
    After drying it works again. Also touch screen.
    However, there is a constant green tint and the display flickers some times.
    I checked already all contacts inside. It seems the water entered at the upper right corner of the phone.
    What part is potentially broken? Display or motherboard?
    Chris
    07-05-2020 03:03 PM
  2. me just saying's Avatar
    Check it in safe mode. Most likely you will need to have an expert look at it. IP68 is not perfect nor is it permanent. It weakens as the phone is used because of all the bumps, drops, exposure to heat, humidity, sprays and more.
    07-05-2020 03:13 PM
  3. mustang7757's Avatar
    Definitely the display is damaged but anything further would have to be opened up and looked at
    07-05-2020 03:38 PM
  4. Mooncatt's Avatar
    At this point, it could be anything and everything. Since water got inside, there's no telling what got wet. Aside from the obvious problem with the display, other components are now at risk of corrosion building up over time and causing problems later on down the line.
    I would strongly consider just replacing the entire phone. At the very least, keep very thorough backups.
    07-05-2020 04:15 PM
  5. Aljean Thein's Avatar
    Where did you dropped it at ? IP68 only protect against regular water. Swimming pool or beach water will ruin your phone.
    07-11-2020 06:46 PM
  6. Mike Dee's Avatar
    IP68 only helps prevent intrusion of any liquid or dust regardless of composition. Regular water will also ruin your phone if it gets inside.
    07-11-2020 07:02 PM
  7. mustang7757's Avatar
    Yup
    07-11-2020 09:11 PM
  8. Aljean Thein's Avatar
    Not true. Swimming pool and beach water are different. The chemicals in them are harsh. IP68 are rated only on fresh water.
    Correct me if I'm wrong but Samsung literally got sued for misleading customers with that same claim.
    Any liquids inside the phone will get ruined, but I was only asking where he dropped it at.
    08-02-2020 01:48 AM
  1. Will copying my data after a factory reset copy a virus?
    By racertron in forum Samsung Galaxy Note 9
    Last Post: 09-19-2020, 12:42 PM
  2. Play store reviews: Do they disappear after a certain time frame?
    By mellandroid in forum Google Play Store
    Last Post: 07-08-2020, 09:08 PM
  3. Google assistant on locked screen Galaxy A40
    Last Post: 07-05-2020, 03:50 PM
  4. My phone screen flickers and is so slow
    By Kitt3n in forum General Help and How To
    Last Post: 07-05-2020, 10:57 AM
  5. Text from my samsung S4 failing after 6-26-20
    Last Post: 07-04-2020, 03:22 PM
