Got a Mate 20 Pro, Ask Questions
Tsepz_GP
1,385
Hi everyone, I have a Mate 20 Pro for review, I have had it since yesterday shortly after the announcement. Much like I did with the Mate 10 Pro last year, if you have any questions with regards to the device please post them here and I will do my best to answer them :)
Here are some pics of my unit, it's an absolute stunner, very well built and features stacked to the hilt. It is curved on both the front and the back, but it's a more gradual curve, unlike the steap curves of the Samsungs, it's also quite compact, I have compared it to a Galaxy S8 below.
neil74
1,287
11
38
As per my other thread does AOD work with 3rd party apps?
Also wondering about pulse width modulation, is it as bad as other OLED screens?
Rickosw
65
Hi Tsepz,
Can you please help me check if both phones are able to shoot pics in RAW Format ? With Manual setting control? eg, ISO, F-stop, TV
also does both phones have AMP for audio ?
how are the speakers? in Mono or Stereo?
Does the video shot in 4K format?
Lastly, if I apply a screen protector onto the phone. Does the finger sensor still work?
Many thanks
recDNA
8,692
112
63
Does ir blaster have a built in app that works well? How is reception in LTE in your network compared to other phones
Aljean Thein
3,229
Does that unit bands works with atnt lte bands ? And did they finally put HDR on auto instead of manually activating it ? Picture samples please.
Tsepz_GP
1,385
Hi Tsepz,
Many thanks
Hi Rickosw
With regards to Music, the phone supports Dolby Atmos only if you have headphones plugged in, please see below screen shot, with Dolby Atmos it allows adjusting equalizers and it gives your music more depth, however I don't believe there is a full on audio chip like the LGs have for example.
With regards to Camera, yes you can save in RAW format, there is an option to turn this on in the settings.
It does support shooting in 4K @ 30 FPS
dov1978
Trusted Member
Oct 22, 2012
1,749
Dammit. You beat me to it again. I doubt it does but I feel I still need to ask if they've actually listened to us yet and added 3rd party notifications
dov1978
Trusted Member
Oct 22, 2012
1,749
Hey, is the notification led still the same tiny, almost invisible one from last year or is it any better? It did look bigger and brighter on a YouTube video I watched but that could just be wishful thinking on my part
Tsepz_GP
1,385
It does indeed, it has an app called Smart Remote
LTE reception has been great and so has WiFi, it holds a stronger LTE connection than my Galaxy Note8 and the iPhone X we have here at home.
Tsepz_GP
1,385
How's the battery life ?....how's are the cameras
Battery Life is good, I did an initial run on the first charge that gave me over 6hours SOT over 14hours of usage, take note this is an initial run and the battery still needs to settle so it can only get better, here are some screenshots
In terms of camera I will be putting together some pics to share, have not had time yet to do this.
Tsepz_GP
1,385
I am not in the USA so unfortunately have no idea what networks it will work on as I am in the EMEA region.
Will post pics later in the week and over the weekend.
Tsepz_GP
1,385
Nope, unfortunately no 3rd party support currently, this may change but right now, no.
Tsepz_GP
1,385
It is still quite small but it seems brighter. It sits next to the speaker grill now, more centralized, which helps.
lucharmer
