I know there's a clear cover included but is there a screen protector fitted like the P20 Pro? Thanks, David.
Yes, the retail units will have a screen protector just like the P20 and Mate 10 did.I know there's a clear cover included but is there a screen protector fitted like the P20 Pro? Thanks, David.
Thank youYes, the retail units will have a screen protector just like the P20 and Mate 10 did.
Thanks for that, I've got a glass protector now anyway and a decent caseWell, there isn't one fitted out of the box, but they do exist. Amazon has a few, and one claims to be a 3D hot fix that also covers the sides.
Also a bit confused why youtubers are getting a plastic case in their unboxing videos, I didn't get one with mine (arrived today). Unless UK market is different. So scared of dropping this thing before a case arrives
Does the fingerprint sensor work with the protector.
What screen protector do you recommend? I've bought three different types now that all just didn't fit.
Thanks so much for your kind reply! The sad thing is that I can't order it to Norway...
Thanks again. Seems like no one are shipping to Norway. It's so difficult to find a screen protector that I wonder if I should dare to keep the phone or not.
