Save big + get 3 months free! Sign up for ExpressVPN today
  1. dc52ltr's Avatar
    I know there's a clear cover included but is there a screen protector fitted like the P20 Pro? Thanks, David.
    10-20-2018 05:41 AM
  2. Tsepz_GP's Avatar
    Yes, the retail units will have a screen protector just like the P20 and Mate 10 did.
    10-20-2018 08:01 AM
  3. dc52ltr's Avatar
    Thank you
    10-20-2018 08:26 AM
  4. tabberkev's Avatar
    Well, there isn't one fitted out of the box, but they do exist. Amazon has a few, and one claims to be a 3D hot fix that also covers the sides.
    Also a bit confused why youtubers are getting a plastic case in their unboxing videos, I didn't get one with mine (arrived today). Unless UK market is different. So scared of dropping this thing before a case arrives :-)
    10-26-2018 10:19 AM
  5. dc52ltr's Avatar
    Thanks for that, I've got a glass protector now anyway and a decent case
    10-26-2018 11:07 AM
  6. johnsamuels's Avatar
    I think the case in the box varies by market. Here in Italy we're supposed to get the clear case. I'll know next week,
    10-27-2018 05:24 AM
  7. dc52ltr's Avatar
    UK owner, no case or screen protector.
    sumzitup likes this.
    10-27-2018 06:03 AM
  8. alansabout's Avatar
    Same with mine. UK
    10-27-2018 06:36 AM
  9. Cocanuta's Avatar
    UK too, very disappointed at the lack of case or screen protector. A friend got a P20 pro a few months ago and it came with both, I expected the same standard if I'm honest.
    10-27-2018 07:23 PM
  10. Kissit46's Avatar
    Does the fingerprint sensor work with the protector.
    10-28-2018 01:25 PM
  11. dc52ltr's Avatar
    The P20 Pro Screen protector doesn't cover the fingerprint scanner as it is on the bottom of the phone, not like the Mate 20 Pro which is in the screen. I wonder if any areas outside the UK have an installed "plastic" screen protector which works OK with the in screen fingerprint sensor?
    10-28-2018 01:54 PM
  12. Aljean Thein's Avatar
    Plastic screen protectors works just fine. at least the one I got on Amazon works fine.
    11-03-2018 06:59 AM
  13. torbjornhb's Avatar
    What screen protector do you recommend? I've bought three different types now that all just didn't fit.
    11-08-2018 01:59 AM
  14. Aljean Thein's Avatar
    This one works. Make sure to position it perfectly though. It fit exactly on the screen and on the edge
    Attached Thumbnails Is There A Screen Protector Fitted To The Mate 20 Pro?-3848.jpg
    torbjornhb likes this.
    11-08-2018 03:16 AM
  15. torbjornhb's Avatar
    Thanks so much for your kind reply! The sad thing is that I can't order it to Norway...
    11-08-2018 03:19 AM
  16. Aljean Thein's Avatar
    Try this one. It was the first one I ordered and worked just fine.
    Attached Thumbnails Is There A Screen Protector Fitted To The Mate 20 Pro?-3875.jpg
    11-08-2018 05:57 AM
  17. torbjornhb's Avatar
    Thanks again. Seems like no one are shipping to Norway. It's so difficult to find a screen protector that I wonder if I should dare to keep the phone or not.
    11-08-2018 08:08 AM
  18. Aljean Thein's Avatar
    Try eBay
    11-08-2018 09:07 AM
  19. dc52ltr's Avatar
    Can you not get it from Amazon UK?
    11-08-2018 09:09 AM
  20. torbjornhb's Avatar
    No. Unfortunately... Very few sellers ship to Norway. Ebay is better
    11-08-2018 02:43 PM
  21. dc52ltr's Avatar
    If you find something you'd like from Amazon UK I'll buy it on your behalf and post it to Norway for you if that would help?
    11-08-2018 03:21 PM
  22. z06mike's Avatar
    Mine came with a case but no screen protector.
    11-08-2018 10:11 PM
  23. gnote2tmo's Avatar
    UK market doesn't get the free case in your box. international ones do
    01-01-2019 04:56 PM
  24. gnote2tmo's Avatar
    I found one on Amazon, tempered glass the comes with a UV light all for $10! And the best part is that the fingerprint scanner works flawless.
    NI-SHEN Compatible Huawei Mate 20... https://www.amazon.com/dp/B07L5KFXVK...cUvbUpU6437900
    01-06-2019 04:00 PM
  1. Problems with syncing google calendar from A3 to google calendar on PC
    Last Post: 11-01-2018, 06:06 PM
  2. Replies: 156
    Last Post: 10-28-2018, 07:33 AM
  3. Replies: 3
    Last Post: 10-20-2018, 03:01 PM
  4. When I press the volume up button for media it's not increasing how to solve it
    Last Post: 10-20-2018, 12:34 PM
