01-04-2019 09:02 AM
96 ... 234
tools
  1. Clayton Crawford's Avatar
    I am in the US, I'm in Atlanta, my Huawei Mate 20 X EVR-L29 works perfectly for me, I get perfect 4G LTE on AT&T network, I've no complaints with this phone.
    It's hands down the best phone made thus far !
    If anyone is using this phone in USA it would be great to hear about it! Thanks!
    12-16-2018 10:57 AM
  2. recDNA's Avatar
    Where did you purchase it? Does wifi calling work? Thanks!
    12-16-2018 10:58 AM
  3. Clayton Crawford's Avatar
    I bought it on eBay.
    You can buy it off of eBay & Amazon.
    I don't know if WiFi calling works, I never used when I had a post paid plan & I don't think it's an option with prepaid plans.
    I don't see why it wouldn't work.
    Everything else works perfectly.
    12-16-2018 03:00 PM
  4. DamianP's Avatar
    ATT wifi (and Volte) typically only works on ATT branded devices, but there are exceptions like the Pixel 3.(which I believe is a first)
    12-16-2018 05:23 PM
  5. andrew_ackley's Avatar
    I have a mate 20 pro which is essentially the same phone on at&t in the US and I can't even find the option in settings to enable it. So you probably can't get it. I have the international model not the Chinese one.
    Clayton Crawford likes this.
    12-16-2018 07:56 PM
  6. rosenr9286t's Avatar
    I've just received my Mate 20 X L29. In the process of setting it up, and I've run into a problem. I use Microsoft Exchange for my work e-mail, contacts, and calendar. I also have a g-mail e-mail account. On my previous Android phones, Outlook for Android syncs with the Exchange servers, and e-mail and calendar are accessed through the Outlook app. Contacts syncs with the Android Contacts app. When I tried to set up outlook, email and calendar work seamlessly, but the contacts will not sync with the Android contacts app. I get a message "Sync is currently experiencing problems. It will be back shortly", and there is a sync circle with an exclamation point in it.
    Anyone else experience this and have you found a solution?
    Ron
    12-20-2018 12:18 PM
  7. rosenr9286t's Avatar
    Found the solution! Outlook for Android has an additional setting to allow the syncing of contacts. All working now.
    Ron
    Scienceguy Labs likes this.
    12-21-2018 08:39 AM
  8. rosenr9286t's Avatar
    Here is the size comparison between the Mate 20 X, Note 8 phone, and Note 8.0 tablet
    The Mate 20 X is only about 1 cm wider and longer than the Note 8 phone, but, at least so far, seems to be better for extended note-taking. Better battery-life and clearer and louder speakers are two noticeable features, along with the differences between Android 8 and 9.
    Ron
    12-21-2018 08:45 AM
  9. rosenr9286t's Avatar
    Some have said that the Mate 20 X uses Wacom AES pen technology. Any ideas about a Wacom AES alternative to the Huawei Mate M-Pen?
    Ron
    12-22-2018 09:36 AM
  10. Scienceguy Labs's Avatar
    I doubt it. Most likely, Huawei is not going to allow any other writing tech to be used successfully in the M20X. I don't know exactly what tech each one uses, but before my M-Pen arrived, I tried out the two Dell pens I have (V8Pro and V11Pro) and neither worked. I also tried out my friend's Apple pencil with the same results.
    I would just go ahead and buy the Huawei pen if I were you. It's a really nicely done device. My only complaint is the lack of cases with pen slots or some other type of pen holster.
    Ron
    12-24-2018 08:48 AM
  11. rosenr9286t's Avatar
    There is a case with a pen-holder on e-bay. A bit pricey, but worth it to me to be able to carry the pen with the phone.
    https://rover.ebay.com/rover/1/711-5...527%3Fchn%3Dps
    Ron
    12-24-2018 02:45 PM
  12. DJW351981's Avatar
    Ron
    That is nice, thanks for this info.
    12-24-2018 03:55 PM
  13. Scienceguy Labs's Avatar
    Thanks for this.
    Ron
    12-24-2018 08:39 PM
  14. worldsoutro's Avatar
    it's a pass for me. doesn't support lte 66, 71 nor wifi calling
    12-26-2018 03:52 PM
  15. souvenir1's Avatar
    Thanks Meter: 1
    hello i have a momax built in pen holder case, and the m-pen for mate 20x, which I have no use, anyone interested please contact me thanks.
    01-03-2019 06:51 AM
  16. Derek W1's Avatar
    Thanks Meter: 1
    I'm interested, what do you want for it?
    01-03-2019 09:04 AM
  17. souvenir1's Avatar
    thanks for reply. I am looking to sell them, shall we chat in PM? thanks
    01-03-2019 10:05 AM
  18. Derek W1's Avatar
    Sure, what pm would you like to use?
    01-03-2019 05:05 PM
  19. souvenir1's Avatar
    I have sent message to your inbox please check thanks.
    01-04-2019 01:09 AM
  20. Derek W1's Avatar
    Ok, I feel dumb but, I don't know how to get to any private inbox on this site
    01-04-2019 08:27 AM
  21. souvenir1's Avatar
    lol on top right, then scroll a bit down?
    01-04-2019 09:02 AM
96 ... 234
  1. No Ai cinema on my Mate 20 pro
    By terkje in forum Huawei Mate 20 & Huawei Mate 20 Pro
    Last Post: 12-08-2018, 05:12 PM
  2. Anyone Getting Huawei Mate 20 Pro
    By jeetu4444 in forum Samsung Galaxy Note 9
    Last Post: 11-01-2018, 02:17 PM
  3. Does the Mate 20 Pro support Google Assistant?
    By Snappy Phoenix in forum Huawei Mate 20 & Huawei Mate 20 Pro
    Last Post: 10-26-2018, 10:22 AM
  4. Mate 20 Pro price
    By TalkofNY26 in forum Huawei Mate 20 & Huawei Mate 20 Pro
    Last Post: 10-24-2018, 09:52 PM
  5. My pro 20 is asking for pin number i have not got a clue about any pin numbers
    Last Post: 10-24-2018, 04:38 PM
