    I've just noticed on my first nightshift that on darker backgrounds and apps/video that on the bottom right of the screen up about half way.. 3 want me to do a factory reset before they do anything but surely that won't fix it or am I been stupid?
    10-29-2018 03:58 AM
  2. belodion's Avatar
    Screen bleed is a physical phenomenon which would not be affected by a reset. Perhaps they suggested the reset for another reason.
    I'll move the thread to the Mate 20 Pro forum, where other users will be able to tell you whether the device is prone to that.
    10-29-2018 05:38 AM
  1. Replies: 2
    Last Post: 10-29-2018, 09:51 AM
  2. Hizpo headunit with inverted screen
    By copeland1969 in forum The Automotive Lounge
    Last Post: 10-29-2018, 07:12 AM
  3. Can Zagg Screen Protector Spray hurt Phone?
    Last Post: 10-28-2018, 11:27 PM
  4. News App that works with the Screen Saver
    By Kayza in forum Android Apps
    Last Post: 10-28-2018, 07:36 PM
  5. Replies: 1
    Last Post: 10-28-2018, 06:23 PM
