1. Epwhamilton's Avatar
    While going through the settings on the phone recently I realised that Wi-Fi was set to 2.4 rather than 5 gigahertz. The advanced settings tab doesn't seem to be there in Wi-Fi however so does anyone know how to change this to use the faster 5 ghz band?
    11-20-2018 05:42 AM
  2. dc52ltr's Avatar
    Had a quick looky ,sorry can`t find that setting.
    11-20-2018 05:54 AM
  3. Rukbat's Avatar
    The easiest way is to name the connections differently - add a "5" to the end of the name of the 5GHz connection (in the router). then choose that one to connect to.
    11-20-2018 02:27 PM
  4. Epwhamilton's Avatar
    Thanks Rukbat.
    11-20-2018 03:46 PM
  5. dc52ltr's Avatar
    Funnily enough thats exactly what I did myself ,works a treat!
    11-20-2018 05:23 PM
  6. Snappy Phoenix's Avatar
    Thanks Rukbat.
    I would only connect my phones to the 2.4 GHz Network because it really doesn't matter, it's not like you'll be downloading multiple gigs of data that require the increased speed of the 5GHz network AND the 2.4GHz has better WiFi range and consumes less battery due to that.
    11-20-2018 09:14 PM
  1. how to send massages many people...?
    Last Post: 11-21-2018, 01:55 AM
  2. how to reset my 203sh aqous phone?
    Last Post: 11-20-2018, 02:29 PM
  3. Why can I not reply to emails on my Samsung galaxy S5 mini
    Last Post: 11-20-2018, 12:49 PM
  4. Adds that keeps on to pop up
    Last Post: 11-20-2018, 05:04 AM
  5. How to see my usage history of Find My Device?
    Last Post: 11-20-2018, 05:02 AM
