1. andrew_ackley's Avatar
    There's literally 134 page thread on xda and not a peep on here. Here's the link to that thread:
    https://forum.xda-developers.com/mat...859268/page134
    Has anyone checked their device yet? There's a app on the play store called Hw device info that you can use to see which screen supplier your phone has. Many of them that do show the green bleeding get much worse over time. This is a bigger issue for us in the US that import it because there is no way to get warranty support.
    Here is a link to the app you can use to check your screen:
    https://play.google.com/store/apps/d...=com.mate20pro
    It's a gray background. Slide the brightness down to close to zero in a very dark room and if yours is affected you will see the green like on mine. Hope this helps. Thanks.
    11-20-2018 12:46 PM
  2. Rukbat's Avatar
    Post #1332 seems to have the solution - cure the screen with UV light until it stops (maybe half an hour).
    11-20-2018 01:10 PM
  3. Schmidt84's Avatar
    I am switching back to iPhone. I will never buy a Huawei again. It's the worst **** ever.
    11-20-2018 01:45 PM
  4. Tsepz_GP's Avatar
    Got a BOE display so I am all good.
    JZ VR likes this.
    11-20-2018 01:47 PM
  5. andrew_ackley's Avatar
    Lucky you
    Maybe? That seems like a weird thing to do. Maybe they rushed the devices out? If it's that easy of a fix surely they wouldn't be replacing devices over it.
    11-20-2018 02:33 PM
  6. CTalman's Avatar
    I've been posting directly on a the Huawei forums. I returned my first device to o2 (they've been very good about it all, as have many other UK suppliers as per others posts) and got my second device yesterday, another LG screen!
    I'm hoping it's from a good batch and won't green screen bleed!
    Real shame as its a great phone.
    11-20-2018 05:32 PM
  7. dov1978's Avatar
    It makes a little sense tbh. When you bond the outer glass to the digitiser they use UV light to cure the bonding agent. Same when you buy replacement glass kits on ebay for phones, they supply a UV torch to do it yourself. Maybe the LG screens have left the factory not being cured long enough and someone has discovered it themselves at home. Definitely worth a try for users in the US with issues as it's a lot easier than paying out.
    Seems like Huawei finally made a phone that had mass appeal and LG have screwed it for them with their supplied displays. This'll certainly put a lot of people off giving them a second chance when they were probably sceptical beforehand
    11-21-2018 08:39 AM
  8. andrew_ackley's Avatar
    Yeah that's true I may have to try this to see if it helps. Haven't been able to call Malaysia and they haven't responded by email. That's the way Huawei service works. You have to do service in the country of origin. I may not even be able to get service but I haven't been able to confirm that with them. I can't even use the Malaysia toll free number here in the US.
    11-21-2018 09:08 AM
  9. DamianP's Avatar
    You can blame LG, Huawei owns the process and QA both the product and suppliers. Fault is all theirs IMO.
    11-21-2018 01:28 PM
  10. Snappy Phoenix's Avatar
    never buying a Huawei phone ever again! Thank God I canceled my pre-order as I have many friends here that bought this phone and have the same issues with the screen here in Dubai.
    What's worse is that all those reviews on YouTube make it sound like the best thing ever made since sliced bread but no one talks about these little things like screen issues or OS bugs that we're seeing.
    11-21-2018 05:04 PM
  11. Yobo1987's Avatar
    Money my friend, money.
    11-26-2018 03:33 PM
  12. JZ VR's Avatar
    LG dropped the ball here once again, units using Chinese BOE screens are fine. If you're in the US trying contacting Huawei Canada customer support to see if you can work something out.
    Tsepz_GP likes this.
    11-27-2018 04:52 AM
  13. andrew_ackley's Avatar
    Ha tried that. They just sent me the link to the Singapore support site which I've emailed a couple times with no luck. Guess I'm just sol lol. Canada won't offer service and neither will Huawei USA. I can't even find social network accounts for Huawei Singapore and their toll free number won't work here in the US. 😔
    11-29-2018 11:35 AM
  14. dc52ltr's Avatar
    I've got an LG screen with no problems(EE UK)... in fact this is one of the best devices I've ever owned.. Love it
    11-29-2018 08:47 PM
  15. andrew_ackley's Avatar
    Have you used the app to check it? Put it on brightness 5 or 10.
    11-30-2018 11:12 AM
  16. dc52ltr's Avatar
    Yep, downloaded the app to check. Set it on low brightness, all ok
    LG screen, right? Huawei MATE 20 Pro green screen issue-screenshot_20181201_005243_ru.andr7e.deviceinfohw.jpeg
    andrew_ackley likes this.
    11-30-2018 07:50 PM
  17. dov1978's Avatar
    From what I've read it's not even all the LG screens anyway. Just a bad batch that were rushed out.
    12-01-2018 04:38 AM
  18. lorenzodiloreto diloreto's Avatar
    I'm in taiwan and bought my huawei mate 20 pro a couple weeks ago, in a few day I was already having the green screen issue and I got it changed at the store that I bought. This happened like a week ago. And now on this other mate 20 pro, that also has a LG screen, I have the same problem. What should I do now?
    12-04-2018 07:42 PM
  19. andrew_ackley's Avatar
    Definitely get it swapped again. Huawei has supposedly been good about swapping them out multiple times if necessary. I wouldnt leave the store without checking it.
    12-04-2018 09:19 PM
  20. andrew_ackley's Avatar
    I was informed Huawei will not let me send my phone in through the mail for service in Singapore. What good is a warranty if I have to visit in person? If they don't rectify this I'm never buying a Huawei phone again.
    12-11-2018 11:16 AM
  21. jeetu4444's Avatar
    Guys just noticed this...is this a issue Huawei MATE 20 Pro green screen issue-20190313_234727.jpg
    04-19-2019 10:40 AM
  22. jeetu4444's Avatar
    Newaz got my screen replaced under warranty to be safe and the good part I had many small and 1 big scratch on my phone display... Happy to have new one on my phone and its brand new again...
    04-23-2019 07:59 AM
  1. Regarding broken screen
    By Android Central Question in forum Samsung Galaxy J Series
    Last Post: 11-20-2018, 01:57 PM
  2. copy files to Huawei p20 pro
    Last Post: 11-20-2018, 11:14 AM
  3. WiFi, Bluetooth and GPS shortcuts one Home screen
    By Tim98TA in forum Samsung Galaxy S9 & S9+
    Last Post: 11-20-2018, 09:41 AM
  4. Regarding broken screen
    Last Post: 11-20-2018, 07:35 AM
  5. How do I get my original home screens back on my Android phone.
    Last Post: 11-20-2018, 01:25 AM
