1. Timo Tonismae's Avatar
    Hey.
    Couple of days ago got mate20 pro. Love the phone. Took it out for some night photography and saw some kind of flare on the pictures. Is it normal? The first picture you can see 3 blue dots one bigger than the others. Second picture zoomed in you can see dots above the streetligihts. Is it normal?
    Attached Thumbnails Mate 20 pro lens flare?-img_20181125_171618.jpg   Mate 20 pro lens flare?-img_20181123_200800.jpg
    11-26-2018 03:31 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! I don't have the same phone to compare, but pretty much all lenses will have some degree of lens flare, so it's not surprising.
    11-26-2018 02:44 PM
  3. Fred98TJ's Avatar
    Yes, normal. It’s not really lens flare, it’s internal reflection inside the lens. Pretty much all cameras do it to some extent or other
    B. Diddy likes this.
    11-26-2018 06:22 PM
  4. dc52ltr's Avatar
    Hey.
    Just another UFO invasion, nothing to worry about!
    11-26-2018 07:59 PM
  5. B. Diddy's Avatar
    The Truth Is Out There.
    11-26-2018 08:56 PM
  6. jeetu4444's Avatar
    Hey.
    Make sure your lens is absolute clean and has no smudges
    12-07-2018 10:38 AM
  7. DamianP's Avatar
    if you watch any of the YouTube reviews of the Mate 20, lens flare seems to be an issue compared to other phones.
    12-07-2018 10:59 AM
  8. Fred98TJ's Avatar
    All phones do that and cameras also, to some extent or other.
    12-07-2018 06:08 PM
  1. Replies: 0
    Last Post: 11-25-2018, 09:12 PM
  2. Compatible recovery software for broken Huawei P20 Pro
    By stevie1995 in forum General Help and How To
    Last Post: 11-25-2018, 01:30 PM
  3. Gear Fit 2 Pro wifi authentication error.
    By maharris2388 in forum Samsung Gear Fit 2 Pro
    Last Post: 11-25-2018, 11:36 AM
  4. Why does my s9+ die at 20%?
    Last Post: 11-25-2018, 11:07 AM
  5. do you know what's this logo sticked behind huawei mate 20 pro?
    Last Post: 11-24-2018, 08:50 PM
