It does and no it's not very good at all.
Samsung Galaxy S9/S9 Plus?Thanks for your feedback. Can you recommend any other models with similar specifications and a good notification light. I have a Samsung S5 at the moment and couldn't be happier with its LED.
Fair enough. Well the S10 variants are just around the corner if you have the patience to wait a couple of months.Thought of that but prefer something that was launched with Android Pie given that most phones only get two OS upgrades.
I'm not sure, with the bezel all but disappearing and there only being a hole I couldn't say for sure.Any clue as to whether the S10 lite/E variant will have a notification light ?
I have the Mate 20 pro and whilst the led light isn't the best it works for me. I can see it flashing away when there is a notification.
