1. lambada24's Avatar
    Does anyone know if the Mate 20 has a LED notification light and if it's any good?
    02-11-2019 03:11 AM
  2. neil74's Avatar
    It does and no it's not very good at all.
    02-11-2019 11:34 AM
  3. lambada24's Avatar
    Thanks for your feedback. Can you recommend any other models with similar specifications and a good notification light. I have a Samsung S5 at the moment and couldn't be happier with its LED.
    02-11-2019 01:22 PM
  4. Maximo_Mark79's Avatar
    Samsung Galaxy S9/S9 Plus?
    02-12-2019 03:10 AM
  5. lambada24's Avatar
    Thought of that but prefer something that was launched with Android Pie given that most phones only get two OS upgrades.
    02-12-2019 03:21 AM
  6. Maximo_Mark79's Avatar
    Fair enough. Well the S10 variants are just around the corner if you have the patience to wait a couple of months.
    02-12-2019 05:25 AM
  7. lambada24's Avatar
    Any clue as to whether the S10 lite/E variant will have a notification light ?
    02-12-2019 05:33 AM
  8. Maximo_Mark79's Avatar
    I'm not sure, with the bezel all but disappearing and there only being a hole I couldn't say for sure.
    I have the Mate 20 pro and whilst the led light isn't the best it works for me. I can see it flashing away when there is a notification.
    02-12-2019 07:15 AM
  9. lambada24's Avatar
    Do the mate 20 and the pro have the same size led light? Is there an easy way how I can invoke the light to switch on when testing out a phone in a shop?
    02-12-2019 07:33 AM
  10. JZ VR's Avatar
    The LED light is small but it's good enough, you won't miss it. Couldn't be happier with the Mate 20 Pro honestly by far the best phone out now.
    02-13-2019 03:13 AM
  1. No notification sound when headphones are plugged in - after Pie upgrade
    By ScottAlex3 in forum Samsung Galaxy S9 & S9+
    Last Post: 04-14-2019, 02:28 AM
  2. Identify App Notification Icon
    By Andrew2241 in forum Ask a Question
    Last Post: 02-11-2019, 12:18 PM
  3. Replies: 1
    Last Post: 02-11-2019, 11:19 AM
  4. Why are my text message notifications for my Gear Fit2 Pro turning off all of the sudden?
    By Android Central Question in forum Samsung Gear Fit 2 Pro
    Last Post: 02-10-2019, 11:06 PM
  5. How do u set up different notification sounds for each app
    Last Post: 02-10-2019, 03:13 PM
