Tried to change the alarm sound from default "forest melody" to "aegean sea" but it doesn't change. Shows the new sound but just vibrates. Does this no matter what I set it at.
Is it just my phone or has anyone successfully changed.
Printable View
Have you tried just playing "aegean sea"? That file may be bad. (Alarm sounds are just sound files, like music files.)
After shutting and rebooting I now get the different sounds, all I was getting before was vibration.
We are good now.
Glad you got it worked out!
