1. SaifulIslam's Avatar
    How many of you guys that are using supcase with your mate20pro? Did you remove the built-in screenprotector that comes together with your case?
    02-20-2019 08:22 PM
  2. Hermes Hidayat's Avatar
    I have never used cases other than UAG. But i would say its better to remove in order for fingerprint to work.
    02-21-2019 01:13 AM
  3. SaifulIslam's Avatar
    Did you used any protection for you screen? The built in screen protector that comes with supcase feels cheap.
    02-21-2019 03:50 AM
  4. gtt1's Avatar
    What screen protector? Mine only had the back case. Canadian product?
    I thought I read somewhere someone mentioned a plastic film on the front. My wife's Honor 6x came with that but very noticeable nothing like that on my Mate that's visible.
    02-21-2019 10:17 AM
  5. Aljean Thein's Avatar
    Mine didn't come with any screen protector. Just a clear case.
    If that case comes with a tempered glass with the front case then itll ruin your in display fps.
    only plastic screen protector works with it
    02-25-2019 09:23 AM
  1. Anyone interested in the S10e for size alone?
    By libra89 in forum Samsung Galaxy S10e
    Last Post: 06-20-2019, 06:42 PM
  2. S10+ or will you wait for Note 10
    By blopez24 in forum Samsung Galaxy S10 & S10+
    Last Post: 02-23-2019, 04:56 PM
  3. I need a PHOTO TIMESTAMP for existing photos on my Note 8.
    By Android Central Question in forum Android Apps
    Last Post: 02-20-2019, 08:44 PM
  4. I need a PHOTO TIMESTAMP for existing photos on my Note 8.
    Last Post: 02-20-2019, 02:39 PM
