Save big + get 3 months free! Sign up for ExpressVPN today
  1. EricMartinSoCal's Avatar
    I was just about to purchase a Mate 20 or Pro but I've been a little put off by the multitudes of people complaining about the green screen and glue issues. Does it affect both phones? Is there a certain production number or model that I should get to minimize the issue? I'm in the USA and buying online so I don't have warranty and will only be able to return based on whatever policy the seller has on Amazon etc.
    03-01-2019 04:52 PM
  2. critta71's Avatar
    My wife has a mate 20 pro. had since december and screen is working fine. The phone itself is amazing and the camera/photos leave my mate 10 pro in their dust. I have read they have used 2 different manufacturers for the screens.
    see attached. For the record I am in Australia..
    https://www.channelnews.com.au/optus...-screen-issue/
    Hope that helps
    03-01-2019 06:37 PM
  3. EricMartinSoCal's Avatar
    I wonder how I confirm it is a BOE screen. I will look into that! Thanks.
    03-01-2019 06:43 PM
  4. dc52ltr's Avatar
    03-01-2019 07:41 PM
  5. Hermes Hidayat's Avatar
    Erm, is it possible to ask the seller the version before buying?
    03-01-2019 08:07 PM
  6. EricMartinSoCal's Avatar
    Seems a lot don't know or don't want to know. I was hoping there was a production number or something that might tell us if it was an LG or boe display.
    03-01-2019 08:09 PM
  7. Hermes Hidayat's Avatar
    You cant tell without using 3rd party apps. Unless the seller tells you its a lcd replacement unit.
    03-01-2019 11:54 PM
  8. Tsepz_GP's Avatar
    The Green Screen issue was identified late last year and so they fixed the LG panels, but as of this year they are now more BOE panel Mate 20 Pros vs LG, so you are more likely to get a good screen. However do check with the seller if they offer ones with BOE or LG Display panels.
    This issue only affects the Mate 20 Pro not the regular Mate 20.
    EricMartinSoCal likes this.
    03-02-2019 01:23 AM
  9. jeetu4444's Avatar
    Guys is this a screen issue
    Attached Thumbnails Mate 20 or Pro for less display issues?-20190313_234729.jpg
    04-19-2019 09:38 AM
  1. Does S10 have MST for samsung pay
    By klee0032 in forum Samsung Galaxy S10 & S10+
    Last Post: 01-27-2021, 04:29 PM
  2. Replies: 1
    Last Post: 03-01-2019, 03:55 PM
  3. Nokia 6 Pie update issues
    By 123456 000 in forum Android Pie
    Last Post: 03-01-2019, 01:22 PM
  4. Galaxy Note9 won't vibrate for texts despite settings being correct.
    Last Post: 03-01-2019, 12:14 PM
