    Hi All
    For the life of me I can not find where to change the framerate on the Mate 20 pro.
    I even tried installing google camera but find that the frame rates are not supported by the phone. Actually any framerate for that matter, like its locked down.
    it should be able to do 720 P @ 960 although I think this is done in post. But I would still expect it to do 120 at 720.
    Also via more -> slow mo is restricted to a few seconds and its hard to control when to actually start recording in slow motion, sometimes I may want longer clips like capturing some specific sports shots.
    So the question is where can I change the framerate of Mate 20 pro while recording video?
    03-03-2019 04:18 PM
  2. Rukbat's Avatar
    In the firmware. You'd have to get AOSP, stick in some APIs to change the framerate, add the hardware interface to the Mate 20 Pro, then write a camera app that can call those APIs.
    It's not a trivial project.
    03-03-2019 05:39 PM
  1. How can I change the color of blinking notification light on my Pixel 2?
    Last Post: 03-03-2019, 05:45 PM
  2. Does anyone Know a solution for no GPS signal on Mate 10 Pro after Android 9.0 update?
    By Android Central Question in forum Huawei Mate 10 & Mate 10 Pro
    Last Post: 03-03-2019, 05:41 PM
  3. No internet on phone
    Last Post: 03-03-2019, 03:16 PM
  4. Outlook not sending emails on my S8+
    Last Post: 03-03-2019, 03:10 PM
  5. Replies: 1
    Last Post: 03-03-2019, 12:25 PM
