Save big + get 3 months free! Sign up for ExpressVPN today
  1. Hermes Hidayat's Avatar
    So recently i did make a thread about the NM Card Unexpectedly Removed error. And just today i got the same error around 4 times in less than 3 hours. But no data is lost. Nor did i need to Mount the NM Card.
    *UPDATE*
    Weird but it always happen in the morning GMT +7 indonesia...
    03-03-2019 08:31 PM
  2. Hermes Hidayat's Avatar
    Solution found. Turns out the connecter is loose. Thus using a thin double sided tape gets the job done. Found my answer in XDA.and many users are complaining there as well.
    Update
    The fix failed. Guess ill just let the NM Card become idle...
    03-06-2019 04:02 AM
  3. Aljean Thein's Avatar
    Interesting
    03-09-2019 10:05 PM
  4. Hermes Hidayat's Avatar
    Interesting
    Fix failed. Not gonna use NM Card...
    03-10-2019 08:17 PM
  5. Aljean Thein's Avatar
    How much was the NM card
    03-10-2019 09:52 PM
  6. Hermes Hidayat's Avatar
    Erm... US$157...
    03-11-2019 12:43 AM
  1. Recommendation for a sd card?
    By Lecrae116 in forum Samsung Galaxy S10 & S10+
    Last Post: 03-04-2019, 05:00 AM
  2. How do I make apps install on SD card - Huawei T3 Mediapad
    By Paul Mawson in forum Ask a Question
    Last Post: 03-03-2019, 03:51 AM
  3. Lollipop apk install loop error
    By Ken Zalez in forum Ask a Question
    Last Post: 03-03-2019, 12:33 AM
  4. Replies: 1
    Last Post: 03-03-2019, 12:06 AM
