1. MrFraggle's Avatar
    My wall paper is oversized for a start how do I correct this?
    Left is LG V30 and on the right is the Pro.
    How I do I turn off Google Assistant and remove the notification, top left, which tells me I have switched accounts and Tap to turn 'OK Google' back on.
    03-07-2019 03:14 AM
  2. Hermes Hidayat's Avatar
    https://i.imgur.com/GkTT0zh.jpg
    Hi, i would recommend editing the photo first OR you could screenshot the photo in the album. As they both have different ratio.
    As for the Google account, i dont get what you mean.
    03-07-2019 08:14 AM
  1. Replies: 2
    Last Post: 03-12-2019, 09:23 PM
  2. Not even a little saavy. New today
    By Gmcdaff in forum New to the Forums? Introduce Yourself Here!
    Last Post: 03-09-2019, 05:44 PM
  3. Note 9 notification bar slides down on its own
    By Android Central Question in forum Samsung Galaxy Note 9
    Last Post: 03-07-2019, 12:37 PM
  4. Audible pulsing sound when on the Secure Startup password prompt
    By android_freak1 in forum Samsung Galaxy S9 & S9+
    Last Post: 03-07-2019, 03:01 AM
  5. Replies: 1
    Last Post: 03-07-2019, 02:55 AM
