    hello all , i am currently using mate 9 for the past 2 years and i got to say that i am very happy and satisfied with all the options , durability and usage of this phone.
    now it is time to replace it since i broke it from every possible angel xD , so i am getting very confused of the new device , i wanted to get the mate 20 pro but the gluegate issue was so worrying that i am thinking about getting the mate 20 instead.
    however , some people are saying that P30 is even better than the mate 20 .. now i was really out for it .. maybe switching back to nokia 3310 would be easier than this chouse xD
    anyway , as for p30 is out of question since i dont want to pay this much on a phone that i am certain that i will break :X
    please help!
    04-08-2019 02:29 AM
  2. Aljean Thein's Avatar
    If it took you two years to break your Mate 9, then I'd say get the P30 Pro with a good case.
    You can grab the Honor View 20 for around $500. The price of the Mate 20 Pro dropped quite a bit and you can grab it online for about $700
    04-10-2019 02:39 PM
  3. Tsepz_GP's Avatar
    Honestly? If the camera is not a big deal to you, then go for the Mate 20 Pro, it still has one of the Top Cameras in 2019, same SoC, same Battery, same Supercharger as the P30 and the best Display in Huawei's line of smartphones currently on the market.
    I have both a P30 Pro and a Mate 20 Pro, I am loving the P30 Pro, but I still prefer the Mate 20 Pro's more detailed display, however I also prefer the P30 Pro's larger display with smaller notch, haha, it's hard to pick between the two, but right now I am using thr P30 Pro full-time.
    If the P30 Pro camera is not a big deal to you then you should be very happy with a Mate 20 Pro, which is a beast in its own right.
    csetoue likes this.
    04-11-2019 02:29 PM
  1. IncallU system app or another device spying. Reset n decide
    Last Post: 04-07-2019, 01:56 PM
  2. Troubleshooting tips for slow data signal or SIM card issues
    Last Post: 04-07-2019, 01:50 PM
  3. Replies: 1
    Last Post: 04-07-2019, 12:53 AM
  4. Using Chinese Mate 20 X in North America
    Last Post: 04-06-2019, 08:32 PM
  5. So, I am a Lil confused: should I get rid of it or not???
    Last Post: 04-06-2019, 06:48 PM
