    I heard it's a bit buggy and that the software is kinda bad. Would it be a good idea to replace it with the stock android? Would it perform better and faster?
    Thank you!
    05-02-2019 08:57 AM
  2. Rukbat's Avatar
    Do you have an AOSP with a HAL designed for the Mate 20? If you flash "stock Android" for another phone, you can turn yours into a paperweight. If you need more battery, carry a power pack.
    As for performance, the Kirin 980 isn't a mid-level SoC (it's better than the Snapdragon 835 in my Pixel 2 and, in some tests, better than the 845 in the Pixel 3).
    But, if you want to, you can get a stock AOSP and develop the HAL (or get a version with a Mate 20 HAL) and see if it's any faster.
    05-02-2019 04:38 PM
  3. dc52ltr's Avatar
    It's no more buggy than any other phone, battery is phenomenal and my Mate 20 Pro is as fast as the day I got it.. HTH.
    05-03-2019 03:16 PM
  4. jeetu4444's Avatar
    excellent phone... super fast... awesome battery life... camera is the best...for my blog and social media..I use mate 20 pro....use to use note 9 earlier but mate 20 pro camera is way way better
    05-04-2019 09:24 PM
  5. Tsepz_GP's Avatar
    Thank you!
    Performance and Battery Life are two areas Huawei mastered a long time ago.
    Mate 20 Pro is fast, fluid and I got well over 8hours SOT on a charge over 24hours of heavy usage. Camera is incredible and seriously versatile.
    The P30 Pro is the only other device I would recommend looking at if you want a great all round smartphone, but there are better deals for the Mate 20 Pro.
    05-07-2019 05:13 PM
  6. guittuner's Avatar
    I have mate 20x and it has best battery life I ever seen but it does not have fastcharge
    06-04-2019 07:05 PM
  1. whatis the first step to getting control of my phone
    Last Post: 05-02-2019, 06:05 PM
  2. Monthly data didn't renew - is it the carrier or my phone?
    By venom0706 in forum General News & Discussion
    Last Post: 05-02-2019, 04:41 PM
  3. And Google play my apps not downloading at all pending and get stuck
    By zulum in forum Legacy Android & Other OS's
    Last Post: 05-02-2019, 04:26 PM
  4. My phone died while in odin mode
    Last Post: 05-02-2019, 02:12 PM
  5. How can i resart my Huawei P8lite eventhough its power is not working?
    By Android Central Question in forum Huawei P8 lite
    Last Post: 05-02-2019, 02:03 PM
