1. Ossie1972wastaken's Avatar
    Hi all:
    * I use the Google Calendar app and you cannot turn on/off calendar accounts in one app without them also being toggled in the native phone calendar app. For eg I have various calendar accounts: Google account, Facebook events, holidays, contact birthdays etc. In Google calendar I toggle these on and they are also automatically toggled in the phone calendar. I go into the phone calendar and toggle off, and they authomatically toggle off in Google Calendar. This causes contact birthdays to be doubled-up and appear twice for every contact in Google Calendar - the one for Google Calendar itself, and the one in phone calendar. I have phone calendar toggled off in Google Calendar and this still happens. Any hints to break this link? I don't need/want/use the phone calendar app at all
    * There is a default notification for contact birthdays for the week before the event. Given the above problem this may be the one in either Google Calendar or the phone calendar. I can see the notification rule but can't find the setting to change/delete?
    * I've copied my Google contacts to the phone, and now the phone thinks there are 2 versions of every contact. This may be related to the above. How do I delete contacts off the phone but leave Google contacts - these are the only ones I need/want?
    * Is there any way to make the native clock app display digital rather than analogue?
    * Any hints for increasing the size of previews on the lock screen? I've already tried all the settings I can find
    Thanks all in advance!
    06-28-2019 04:40 PM
  2. frederickdawg's Avatar
    I just removed the Huawei app permission for calender and now I just use Google calendar.
    09-16-2019 09:21 AM
  3. Ossie1972wastaken's Avatar
    I've removed all permissions for native calendar. Same problem
    09-16-2019 03:13 PM
  4. frederickdawg's Avatar
    My issue was that if I turned off Google calender in the Huawei calender app then it would also turn off the sync in my actual Google calendar app. Which I found weird.
    09-16-2019 03:21 PM
  5. Ossie1972wastaken's Avatar
    Calendars in Huawei are broken
    09-16-2019 03:23 PM
  6. frederickdawg's Avatar
    I've effectively denied all permissions which shows this when launching it.
    Some qns for the Huawei Mate 20 Pro-screenshot_20190916_181029_com.android.calendar.jpg
    09-16-2019 05:11 PM
  7. Ossie1972wastaken's Avatar
    I get this
    Some qns for the Huawei Mate 20 Pro-screenshot_20190917_100701_com.google.android.packageinstaller.jpg
    09-19-2019 04:41 PM
  8. frederickdawg's Avatar
    I get this
    From the apps, then calender then permissions menu. Some qns for the Huawei Mate 20 Pro-screenshot_20190919_183318_com.google.android.packageinstaller.jpg
    09-19-2019 05:34 PM
  9. Ossie1972wastaken's Avatar
    From the apps, then calender then permissions menu. Click image for larger version.
    Yep done all that. Still same problem
    09-19-2019 07:16 PM
  10. frederickdawg's Avatar
    Then go-to Google calendar app and set up the Gmail calendar.
    09-19-2019 08:31 PM
  11. Ossie1972wastaken's Avatar
    Thanks frederickdwag for all your suggestions! But everything was already set up as per your tips. Problem as per OP
    09-19-2019 10:36 PM
  12. frederickdawg's Avatar
    Don't know what else to say, sorry. Like mentioned earlier I completely removed all permissions from the Huawei calender app and the attached is the my Google calendar.Some qns for the Huawei Mate 20 Pro-screenshot_20190921_202733.jpg
    09-21-2019 07:30 PM
  13. Rukbat's Avatar
    The phone calendar is showing what's in Google Calendar, so if you put things into both calendars, you're entering them twice. Only put them into one of the calendars - they'll show up in the other one. (If you enter something once, it shouldn't show up twice, unless, you're syncing to another calendar that you're putting them in too. Syncing means put the date in one and it will sync to the others. Don't put it into 2 of them that are synced.)
    09-22-2019 12:24 PM
  14. frederickdawg's Avatar
    The problem I encountered was that if I removed Google calendar from the Huawei calender it would also remove it from the Google calendar app. So in the end I just removed all Huawei calender permissions and stuck with using Google calendar only, which isn't an issue for me since I only use that anyways.
    I just found it odd that Huawei calender would automatically add my Google calendar to sync, yet when I removed it from said calender it would also be removed from Google app calender.
    09-24-2019 01:06 PM
  15. Ossie1972wastaken's Avatar
    Yep this is my problem. It doesn't seem there's a way around this other than removing the phone calendar permissions entirely.
    My issues now are still the default birthday notifications and the doubled-up birthday events. I suspect this is more to do with the contacts being doubled up somehow. How can I delete all contacts saved to the phone directly, so the only contacts are my google contacts? It's easy enough to save a new contact to the phone, but I can't find a setting to delete only those contacts saved to the phone?
    09-25-2019 02:49 PM
  1. Huawei p20 pro Nfc problems
    By Android Central Question in forum Huawei P20 & P20 Pro
    Last Post: 06-30-2019, 12:53 PM
  2. why can't i login in the play store?
    Last Post: 06-29-2019, 08:48 AM
  3. Huawei p20 pro Nfc problems
    Last Post: 06-28-2019, 02:36 PM
  4. not getting + sign/ prefix before countrycode for incoming calls MTK
    Last Post: 06-28-2019, 02:32 PM
  5. question about the exchange app
    Last Post: 06-28-2019, 02:07 PM
