11-27-2019 10:06 AM
52 123
tools
  1. anu3682's Avatar
    Let me know if you're having wifi connection issue like me when updated to Android 10
    on EMUI 10 beta I had some weird issues with wifi and cellular used simultaneously every few seconds causing timeouts while browsing files over my local network. But factory resetting and disabling Adguard apps DNS filtering fixed my issue.
    11-20-2019 02:24 PM
  2. jeetu4444's Avatar
    Having zero issues with android 10...working great... In fact having WiFi issue on my Note 10 plus with beta android 10 beta 2
    11-20-2019 05:10 PM
  3. jeetu4444's Avatar
    Where are you located and what Mate 20 pro version do you have?
    Bro Indian unit factory unlocked
    11-20-2019 05:51 PM
  4. frederickdawg's Avatar
    Tried it for again for while week this time around, back to 9.1 and this time it's for good.
    11-21-2019 05:14 AM
  5. jeetu4444's Avatar
    I already have official stable Android 10 on my mate 20 pro...working great
    11-21-2019 10:22 AM
  6. frederickdawg's Avatar
    I was on official also 10.0.0.180 doesn't do anything for me. In fact some of my apps don't work anymore.
    11-21-2019 10:25 AM
  7. Aljean Thein's Avatar
    How to downgrade back to 9.1
    11-21-2019 01:42 PM
  8. frederickdawg's Avatar
    Use hisuite on PC. Select backup or restore ( sorry forgot which one ) then you'll have an option to check older version which will roll you back.
    11-21-2019 01:45 PM
  9. jeetu4444's Avatar
    Which apps.....
    11-21-2019 06:20 PM
  10. frederickdawg's Avatar
    Which apps.....
    Accubattery pro and GSAM were the most evident that come to mind.
    11-21-2019 06:23 PM
  11. Javier P's Avatar
    Yup. That was one of the first things I noticed on a different phone. Android 10 rendered those apps useless and I hope they manage to get them working again in the near future.
    frederickdawg likes this.
    11-21-2019 06:28 PM
  12. frederickdawg's Avatar
    Sad as it sounds, I just cannot live without those two apps.
    11-25-2019 07:33 PM
  13. Javier P's Avatar
    Oh, don't worry, you'll get used to that.
    I've seen some people that have no problem with Gsam after Android 10. All of them have the 'more stats' options enabled through root or adb commands, though.
    11-25-2019 07:35 PM
  14. frederickdawg's Avatar
    Yes, more stats are enabled or should I say were enabled Emui 10. Rolled back to 9.1 a few days back.all good.
    Javier P likes this.
    11-25-2019 07:39 PM
  15. Javier P's Avatar
    Mmmm, did you tried selecting Don't optimise for Gsam? I'm going to leave it that way for a day and see what happens. Not sure why I didn't try it before
    11-25-2019 07:54 PM
  16. frederickdawg's Avatar
    Yes, all that was done, optimization off and app launch was set to manual keeping app to run in background. It's not that it wasn't logging data, but the data it was logint was completely wrong. Only feature that worked was perhaps the " since last screen off" measurement. The figures gsam was showing was like used 5% in 48 hours with 14 hours screen time lol
    11-25-2019 08:00 PM
  17. Javier P's Avatar
    Oh well, no much hope for me then.
    11-25-2019 08:01 PM
  18. frederickdawg's Avatar
    Have you tried it?
    11-25-2019 08:09 PM
  19. Javier P's Avatar
    Have you tried it?
    I'm going to do a partial charge, to select the different options, and see what happens tomorrow.
    11-25-2019 08:15 PM
  20. frederickdawg's Avatar
    Partial charge? Lol
    11-25-2019 08:16 PM
  21. Javier P's Avatar
    Partial charge? Lol
    Yes, to check the different stats from last full charge and from last unplugged.
    11-25-2019 08:18 PM
  22. frederickdawg's Avatar
    Oh I see.
    11-25-2019 08:25 PM
  23. Javier P's Avatar
    Have you tried it?
    Three cycles and it seems to be working. Funny reading for WiFi battery percentage but the rest seems good and similar to the stock stats.
    This is what I did, force stop and clear data for Gsam, select don't optimise, open it and leave it alone for a while until finishes calculation, charge and it should be fine.
    Remember that this is with an OP 7.
    11-27-2019 09:45 AM
  24. frederickdawg's Avatar
    LoLz , . I was referring to Huawei Emui 10 and GSAM and Accubattery not working properly on it.
    11-27-2019 10:01 AM
  25. Javier P's Avatar
    Yes, but the same problem happened with other phones after Android 10 including OP. It seems more related to 10 than to an specific brand.
    11-27-2019 10:03 AM
52 123
  1. Doogee 12000 DL Pro Stuck on supported API:3
    Last Post: 10-14-2019, 12:12 PM
  2. 10/1 Sec Update Jiggled Something
    By toenail_flicker in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 10-12-2019, 12:29 PM
  3. What is the best setting for an infrared hot workout on Samsung Galaxy Active Watch?
    By Android Central Question in forum Samsung Galaxy Watch Active
    Last Post: 10-12-2019, 11:00 AM
  4. I can't use my android without service anymore? Is Sprint forcing service?
    Last Post: 10-12-2019, 08:41 AM
