11-27-2019 10:06 AM
52 123
tools
  1. Scienceguy Labs's Avatar
    I still can't get the update.
    11-27-2019 10:04 AM
  2. frederickdawg's Avatar
    Yes, but the same problem happened with other phones after Android 10 including OP. It seems more related to 10 than to an specific brand.
    After EMUI 10, I reset device and started from fresh , same issue with GSAM and Accubattery Pro. The issues were not related to the aggressive power saving features of Emui 9.1, which required me to allow those two apps to be always running in the background. They were also allowed to run in background in Emui 10. In any case, I'm happy to still be on EMUI 9.1,
    11-27-2019 10:06 AM
52 123
  1. Doogee 12000 DL Pro Stuck on supported API:3
    Last Post: 10-14-2019, 12:12 PM
  2. 10/1 Sec Update Jiggled Something
    By toenail_flicker in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 10-12-2019, 12:29 PM
  3. What is the best setting for an infrared hot workout on Samsung Galaxy Active Watch?
    By Android Central Question in forum Samsung Galaxy Watch Active
    Last Post: 10-12-2019, 11:00 AM
  4. I can't use my android without service anymore? Is Sprint forcing service?
    Last Post: 10-12-2019, 08:41 AM
