    Hello everyone i would like to know why i dont recieve update for emui 10 for Mate 20 pro i check in hicare but i want to install it not from hicare
    12-05-2019 08:15 AM
  2. mustang7757's Avatar
    What is hicare ? Have you manually went into settings and check for software update ? I'll leave a link to register so you can communicate here, as a guest account u cant .https://forums.androidcentral.com/sh...d.php?t=409154
    12-05-2019 08:19 AM
  3. B. Diddy's Avatar
    I moved this to the Mate 20 Pro forum for more specific traffic.
    12-05-2019 12:11 PM
  4. frederickdawg's Avatar
    Hicare is an inbuilt Huawei app that one can check warranty and do updates amongst other things with.
    OP, what Cust code and Emui 9 version are you currently on? I've attached a screen shot as an example. Mine shows Android version 9.1.0.346 C432 which is the Cust region code.Emui 10 Mate 20 pro-screenshot_20191208_205705.jpg
    mustang7757 likes this.
    12-08-2019 07:58 PM
  5. mustang7757's Avatar
    OP, what Cust code and Emui 9 version are you currently on? I've attached a screen shot as an example. Mine shows Android version 9.1.0.346 C432 which is the Cust region code.Click image for larger version.
    Oh cool , maybe your advice can help them out .
    12-08-2019 08:00 PM
  6. frederickdawg's Avatar
    Huawei have a real weird way of updating their devices. Thats the first thing I noticed . Unlike Samsung which goes by CSC for example, Huawei use the cust code and IMEI for updates. Couple that with also having to use a sim specific to the phones region, then updates can be non existent.
    12-08-2019 08:06 PM
  7. mustang7757's Avatar
    Interesting, never used Huawei wanted the mate 20 pro never happened . Maybe in future will get one I do like their design and features.
    12-08-2019 08:10 PM
  8. frederickdawg's Avatar
    You need to buy one for "educational purposes" .
    12-09-2019 01:09 AM
  9. mustang7757's Avatar
    frederickdawg likes this.
    12-09-2019 08:35 AM
  10. Aljean Thein's Avatar
    Go to hi care settings. Change your location to Singapore. Some users, including me, received the update once changing the location in hi care.
    12-20-2019 08:14 AM
  1. Possible Solution for Mate 20 Pro LYA-L29 firmware update!
    By Kevilz in forum Huawei Mate 20 & Huawei Mate 20 Pro
    Last Post: 12-08-2019, 08:01 PM
  2. Does the RCA Delta Pro 11 support OTG?
    Last Post: 12-05-2019, 09:25 AM
  3. OxygenOS update 10.0.1 for OnePlus 6 & 6T
    By ironass in forum OnePlus 6 & 6T
    Last Post: 12-04-2019, 08:25 PM
  4. Tab A 10.1 with S pen default storage
    By Zchesney in forum Samsung Galaxy Tab A 10.1 (2019)
    Last Post: 12-04-2019, 10:52 AM
  5. Disable dual sim android 10
    Last Post: 12-04-2019, 07:55 AM
