1. 9ko's Avatar
    After Android 10 my widgets suddenly is no longer working.
    See pic, what is wrong?
    Restart wont fix it, only some stock app widget works.
    Sonos widget etc do not work.
    Attached Thumbnails Widget not working after Android 10?-screenshot_20200118_162608_com.huawei.android.launcher.jpg   Widget not working after Android 10?-screenshot_20200118_162611_com.huawei.android.launcher.jpg
    01-18-2020 10:39 AM
  2. anu3682's Avatar
    Probably the apps with widgets are not compatible with Android 10 check with the respective developer. Alternatively try clearing cache as sometimes after a major upgrade some apps might get currupted during upgrading. Lastly you can try a factory reset which might help.
    01-18-2020 10:47 AM
  3. mustang7757's Avatar
    In each of those apps that have widgets clear cache,data,force stop it
    01-18-2020 11:20 AM
  4. Javier P's Avatar
    Also, have you tried removing the widgets from the home screen and adding them back?
    Rukbat likes this.
    01-18-2020 11:23 AM
  1. How to fix contacts app bug in Android 10?
    Last Post: 07-22-2020, 12:36 PM
  2. G8 refusing to charge immediately after dying
    Last Post: 01-21-2020, 04:32 PM
  3. HELP! NEW S9 Red Light Not On When Charging & Blinks When Off Charger
    By FanGirl4Life in forum Samsung Galaxy S9 & S9+
    Last Post: 01-18-2020, 11:14 PM
  4. Note 10+ not playing m4a files...wft?
    Last Post: 01-18-2020, 06:16 PM
  5. Remotely controlling multiple android phones
    Last Post: 01-18-2020, 04:40 PM
