Huawei Mate 8 dual sim battery after the last update become fast loos with normal use
before that it takes full day now less then 10 hours ??
thank you
Printable View
thank you
Welcome to Android Central! Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
1. The main Settings>Battery screen.
2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
3. The Screen category (to see total Screen On time).
4. The Cell Standby category, if present (to see Time Without Signal).
http://forums.androidcentral.com/amb...d-central.html
