All I'm getting is regular charging. I am using an adapter that fast charged my Nexus 6P. I've learned that doesn't matter. Anyone found a car charger that operates at a faster charging speeds?
Supercharge if I'm not mistaken is slightly different.
You can use any Qualcomm certified Quick Charger Chargers from Amazon.
Try these Samsung fast car charger. Getting my Mate 9 tomorrow. I can test it for you.
I use aukey qc 2.0 and qc 3.0 for my phones and happy with them.Have you tried one that you know works?
Fast charging 60 ℅ in 30 min.
It has quick charge 3. Fast charging is there in it.Well, I went ahead and bought the "AUKEY Car Charger, Flush Fit Quick Charge 3.0 Port for Samsung Galaxy S7/S6/Edge, LG G5, HTC 10 and More". It does not show "fast charging." Does yours show that? Is that the charger you bought?
Not sure where you got that info from but it's wrong. The mate 9 will take advantage of quick charge 2.0 and 3.0 however it isn't as fast as the proprietary Huawei supercharge. It all depends on the cable. If you use Huawei's cable with QC 3.0 chargers you will achieve speeds in the 2000+mA range. Without the Huawei cable you will be under 2000mA. With the Huawei block and cable you will be 3500+mA.Hi,
Yes it is, but not for Huawei gear. Sorry but your information is misleading.Qualcomm fast chargers are none compatible with Huawei products which use HiSilicon fast charger technology.
Anyone who follows your advice will have a charger that will work, but will neither fast charge nor supercharge any Huawei product.
Hi, I will measure the different chargers and cables this evening (UK time.) I can assure you though that if you use a Huawei Quick charger (as distinct from the Huawei Supercharger) on the M9, it will show up as "Fast Charge" with any Huawei cable.
