CWens
I think this is a Android 7 software problem not Huawei....
i've solved by disablig 'voice wakeup' in voice control menu.
Let me no know if it works for you
If you're talking about Settings -> Smart assistance -> Voice control -> Voice wakeup, that settings is already off for me (and was off when the notification kept popping up in Duo) so I don't think that's it for my issue. Glad it worked for you though.
Seems this has been fixed with the latest update that includes Alexa
I'm getting this pop up notification when I use my camera for video (also when I use the Ring app which also uses the microphone). I didn't get it in the past. What part of Google did I change that is causing this? Anyone know?
The annoying part is that it will pop up repeatedly and I have to dismiss it to do anything with the underlying app.
(fyi - I just aimed the camera at my jeans for that picture)
There is a simple fix to this. Go to Google now settings, go to voice settings and turn off OK Google detection from anywhere.... Hope that helps
I think I found a solution, go to Settings}App Permissions}Default App Settings} Assistance and voice input, then make Assist app None instead of Google, this'll turn off Google Assistant and should fix the problem
Ok, everyone is saying they are getting the below message...so I'm wondering, can someone please tell me how to get rid of that message to allow me to use my video because I am missing out on so many first with my newest addition to the family because I can't record. Please bare in mind, I am not very technical
