1. techmizan's Avatar
    Hi all!!!
    I'm screwed!!
    I think I bricked the phone!
    Please help!!
    I have a full partitions backups made with Partitions Backup and Restore App (Root access required). I backup all the partitions, all of them in raw mode. All the files are *.img ready to flash with fastboot.
    The problem
    1. adb is not recognizing the device
    2. fastboot is not recognizing the device
    3. I cannot enter TWRP
    4. Huawei EMUI 3 buttons (volume up + volume down + on/off button) function doesn't start neither (I'm trying to force the update to B132 ROM)
    5. The phone enters directly to Rescue Mode and says
    6. i can't shutdown my phone when i press the power button it will automatically go to the Rescue Mode again.
    So the phone is still working and I got this RESCUE MODE screen but I can't do anything when this screen is displayed.
    Any idea? What can I try?
    Please, I really need your help, anything you can imagine to try please, let me know!!!
    Thanks in advance!!!
    07-26-2017 05:23 AM
  2. Golfdriver97's Avatar
    Welcome to the forums. What were you doing to the device that caused this? You may need to reflash the stock ROM with fastboot commands.
    07-26-2017 10:49 AM
  3. techmizan's Avatar
    i am trying to relock the bootloader then the problem is happened
    i can't do anything, usb not recognizing the device
    ****fastboot is not recognizing the device
    when i command in CMD it will say waiting for device.
    i try to flash using the HUAWEI EMUI updater (by pressing volumn up & power button) but it's not going to the emui uodater mode, it again go to the rescue mode
    please help me what can i do
    07-28-2017 12:56 AM
  4. Golfdriver97's Avatar
    Can the phone be rebooted back into the bootloader?
    07-29-2017 03:06 PM
  5. techmizan's Avatar
    no it will automatically reboot into the rescue mode
    08-03-2017 08:57 AM
  6. Danoo238's Avatar
    Hi Techmizan!!
    Just a question!!
    Did you find a solution?? I have de same problem, and I'm desesperate!!
    02-08-2018 03:31 PM
  1. UK Screen Protector guide
    By bm_999 in forum Samsung Galaxy S8 & S8+ Cases & Accessories
    Last Post: 08-31-2017, 08:42 PM
  2. Replies: 2
    Last Post: 07-27-2017, 11:58 PM
  3. Replies: 0
    Last Post: 07-26-2017, 04:04 AM
  4. Replies: 0
    Last Post: 07-26-2017, 04:02 AM
