Mate 9 issues after Oreo
Vanessa Lynd
51
Anybody experienced any hiccups with Oreo? I find my Bluetooth does not automatically sync with my car FM transmitter unlike the previous update. I have to unpair and connect to the device again. I also cannot change the notification sound for Viber app at it takes me to the new app notification menu.
Brian_d
64
6
I noticed that the icon for text messages does not show the number of unread text messages anymore. It just shows a circle or bubble now
Mike-Mike
1,628
I think that can be fixed
Settings > Apps & Notification > Notification Management > Batch Management > three dots > Badges > Badge Display Mode
Mike-Mike
1,628
I was not getting push notifications promptly. I also have a LG V20 and a Moto Z2 Force. I generally just swap my SIM between the 3 so they all have the same apps on them.
I can see the other 2 devices getting notifications that I am not getting prompted for on my Huawei
editguy
Trusted Member
May 23, 2017
248
Okay, I ran into something new today and don't know whether it's Oreo or Huawei. I used my fingerprint sensor to open my phone and it said that every three days I have to use my pin code for added security. First, how does using the pin code instead of the sensor add security? I don't want the aggravation. I only set it up in the first place because the sensor works so fast. I've now disabled it all (for my purposes, I don't need password or fingerprint security). I'm just wondering where this policy came from.
GentleMuser
13
I am having a problem getting my notification badges all the time. I use Nova and Textra. my batch management, batch display mode was set to "notification message" which I assume is correct. this isn't happening with every message, but it does happen often....
also randomly my text tones go quiet. Doesn't turn my phone to silent. I restarted the phone a couple of times to resolve this temporary situation.....
br77494
206
I was having issues with Oreo replacing the unread message count badge in Textra and replacing it with just a dot. Found a work around in Nova launcher settings, though. Nova Settings > Notification Badges. Several choices there.
Byrese
445
Battery life after update is ridiculous!
bigmick777
218
My Google Now page loads REALLY slow now.
Mine doesn't load any of the cards for ages. It was working on Oreo. I've since updated to the march security patch so it could be that or an update to the Google app.
Basically, when I swipe right the Google now page comes up but I only have the search bar. To get my Google info and cards back I have to keep swiping on / off Google now and eventually they pop up. Tried clearing the Google app cache and data, no difference.
OLD_HATCH
153
Anyone have an issue with location sharing not updating since Oreo update?
Also there seems to be an added "feature" which when phone is placed in a clear plastic waterproof case(Ziploc bag basically) the phone asks to hold power and volume up to unlock phone. Anyone know how to fix these issues?
Byrese
445
Now that you mention it just a little bit sometimes. But it's not that much.
wei34
