1. Hawk Conqui's Avatar
    I cam into a problem recently on my Mediapad M3. I just recently updated to Android 7.0 with EMUI 5, I was hoping this would solve some of the smaller issues I've been having, and it did. Except, it brought on a much bigger problem. Now, if I leave my tablet in sleep mode for over an hour, roughly, the WiFi will disconnect from my network and refuse to reconnect or even see any networks at all. I can't just simply turn the WiFi on and off either as it instantly flips back on as soon as I turn it off. The only temporary way I can get around this is by forcibly restarting the device, it just shows the shutting down symbol infinitely if I do it normally. I was wondering if I could receive some assistance, thanks in advance.
    04-19-2018 09:31 PM
  2. demarcjw's Avatar
    I also have the same problem here. Got my Huawei M3 exactly a month ago and got the Nougat update upon boot up. No issues whatsoever until yesterday. Wifi disconnects, can't find networks, and the on and off switch flips back when switched either way. I heard of security patches update for Feb 2018, but I have not received mine. Hoping that would fix this issue. Like what you said only way to fix this now is reboot the tablet. Yesterday I tried that for the first time, but my tablet became unresponsive, the touch screen stopped working, and so I thought I wasted money on this tablet. I left my tablet to rest for a while and after a couple of hours the screen worked again. But the wifi issues again. Hope anyone has solutions to offer. Thanks
    05-11-2018 09:07 PM
  3. Iggypop2's Avatar
    I'm getting the same thing and have to forcibly restart to get it working again. Hold power off button for 10 seconds. Anyone has, found a solution?
    05-15-2018 12:22 AM
  4. AndrasDucz's Avatar
    Yeah, exact same issue here also..... I think we should all contact Huawei support (I already have), maybe they will solve this in a new update.
    05-15-2018 02:25 PM
  5. demarcjw's Avatar
    I factory reset my device just now after the constant wifi issues. Hoping this will help somehow in the meantime. Will post an update for any improvements if any.
    05-16-2018 12:31 AM
  1. Note 8 and using external lavalier mic
    By DRILLINDK in forum Samsung Galaxy Note 8
    Last Post: 04-25-2018, 11:38 AM
  2. Why is my mobile data not working on my note 4?
    By Jeremy Guiao in forum Samsung Galaxy Note 4
    Last Post: 04-20-2018, 11:45 PM
  3. Google Calendar on my Galaxy 5 not syncing properly
    Last Post: 04-20-2018, 11:44 PM
  4. Expansion file not moved to extSD
    By BobAchgill in forum Android Apps
    Last Post: 04-20-2018, 02:54 PM
  5. Replies: 1
    Last Post: 04-20-2018, 02:22 AM
