1. Orph's Avatar
    Greetings...I'm new here.
    Me:
    * 70 y.o.
    * Pretty much Novice level with Android...have a Levovo Tab 4 8, but have been a mostly desktop fellow. I'm a long way from mastering Android.
    * Not a cell phone user (at this time)
    In reviewing recent benchmarks, Huawei stands out. The MediaPad 5/6 look great!
    Uses to which I'd like to put a tablet
    * In car for backup camera - 2.4MHz/4.8MHz Wi-Fi video transmiter connect? Automatic connect on startup of tablet? Important for this use is 'Bootup Time' for tablet...
    * Navigation in car
    * Amateur radio transceiver connection via Bluetooth (I need to work out the Bluetooth on the radio end...USB Type-B input to radio...Arduino Bluetooth board? Is Bluetooth 5 compatible with Bluetooth 4 bi-directionally?
    General Use
    * Media consumption
    * Internet surfing
    * Stylus pad input for Windows desktop...mirroring? ...both ways? MS Notes..?
    * Are there any clues on Upgrade to Android 10 timeframe?
    * Is doesn't seem there is a Folio Keyboard for the 8.4" as there is for the 10". I have a couple of inexpensive 8" Bluetooth folios/keybaords. Thoughts?
    * It might be nice in the future to surf the internet when a Wi-Fi connection is not available. It 'seems' that Wi-Fi and LTE are mutually exclusive. Is that the case? If so, Wi-Fi wins. Are there alternatives? Thoughts?
    I suppose I should get on Youtube and learn Android better. I haven't even gotten gestures down.
    Maybe Huawei will get a (black/grey) MediaPad M6 to the US market in time for Black Friday/Cyber Monday. Otherwise it appears the M5's are comming down in price.
    What else should I know?
    TIA - Orph
    09-22-2019 09:49 AM
  2. Rukbat's Avatar
    Me:
    * 70 y.o.
    Me: 77, so ...
    Pretty much expert level with Android
    Not unless you're running a camera app to record on start, and a startup app to control what runs on startup.
    No. I don't know of a single ham xcvr that allows Bluetooth connections, or Bluetooth-to-USB conversion. (But I've been off the air for a few years, so maybe there's something available - but it would probably have to be from the xcvr manufacturer.
    * Internet surfing
    Lots of mobile data usage - may be costly.
    Using VNC, maybe - server on the Windows side, client in the tab.
    Not scheduled at all. To 8, possibly, then that's all.
    Any BT keyboard should work - but BT is a "one device at a time" connection. No keyboard and xcvr connection.
    No, in most devices (laptops, desktops), you can only be using one internet connection at a time. (Some servers "dual-home", so you can use 2 NICs to provide 2 simultaneous internet connections.
    Some things, yes - but watch out for one thing. You'll see every "expert" use the Home key to end apps. DON'T! The Home key just runs the launcher (homescreens, app drawer, widgets, wallpaper), it doesn't close the app. The app maintains a cache. When you reboot, many apps loose the connection to the cache, so that's storage you never get back. Use the Back key to end an app. (Youtube is sometimes like watching a novice telling you how to win DX pileups. It sounds good, but you know it will never really work that way.)
    The M5 and M6? The rackmount servers? Or something else? (Rackmounts don't come down in price.)
    Huawei Mediapads? The 5 or 6 may come down in price, and the 6 might get 10, but I doubt it (considering the ban on Huawei). And the only color I see for the 6 is Champagne Gold. The 5 comes in grey. (Maybe someone will come out with a custom ROM for it for 10, but I don';t see anything listed even on LineageOS going back to 8.)
    It's cheaper to buy a second dash cam than a tab?
    09-22-2019 12:07 PM
  3. Orph's Avatar
    - Glad to find some experience here. I wonder if there is a way to startup the tablet by starting the car with remote start...and not having to wait on booting up.
    - Bluetooth Novice as well. I'm trying to find a Bluetooth (Arduino module?) and output to USB Type B input on the rig. Bluetooth USB Type-B cable replacement, so to speak.
    - Thanks!
    - That's okay...I won't be needing a keyboard while operating mobile. Thanks.
    - Thanks. I guess you are saying that an LTE version still has Wi-Fi available, but not necessarilly simultaneous.
    - Thanks
    - ...trying to simplify hardware, cables, etc.
    09-22-2019 12:42 PM
  4. Orph's Avatar
    Last Sunday, I came across an M5 8.4" - 64Gb on eBay (while general searching M5/6). I decided to place the 'minimum bid' on it and perhaps a little more. I got it for the minimum. It arrived A-Ok on Friday.
    09-29-2019 06:08 AM
  1. Hello to all....new to smartphones. Over whelmed in general......
    By krellboy1 in forum New to the Forums? Introduce Yourself Here!
    Last Post: 12-03-2019, 01:45 AM
  2. Edge Lighting notification question
    By the tall guy in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 09-19-2019, 10:21 AM
  3. Replies: 5
    Last Post: 09-18-2019, 02:12 PM
  4. Note 10+ Video questions: Picture in Picture and Floating Shutter button
    By Casey Cheung in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 09-17-2019, 12:40 PM
  5. Questions about using Hiya on a Pixel 3
    By Moondoggy in forum Google Pixel 3 & Pixel 3 XL
    Last Post: 09-16-2019, 01:43 PM
