1. AC Question's Avatar
    My headphones work as I can receive phone calls. FM Radio runs correctly, it can find stations and dial them in. Just no sound. Any ideas?
    08-16-2017 08:55 AM
  2. Rukbat's Avatar
    Are you sure it doesn't need an FM radio app to be running to get sound?
    08-16-2017 12:06 PM
  3. Monty8765's Avatar
    I don't believe so. I installed a radio app, it works but the built-in radio does not. The built-in radio recognizes when I unplug the headphone jack and advises to plug it in so it can act as the antenna.
    08-16-2017 12:50 PM
  4. Monty8765's Avatar
    When I try to run a radio app at the same time as the built-in radio it shuts off the built-in radio.
    08-16-2017 12:53 PM
  5. Aljean Thein's Avatar
    If it has FM radio built in the phone, you don't need an app for it work. Didn't need it on my other phones at least.
    08-18-2017 01:28 AM
  6. Aljean Thein's Avatar
    Did this happened since you got the phone ?
    08-18-2017 01:33 AM
  7. dpham00's Avatar
    How did you use the FM radio with no app?
    08-18-2017 05:48 PM
  8. Aljean Thein's Avatar
    No 3rd party FM radio app needed, I just opened my music app and there was a FM radio section there.
    08-18-2017 05:56 PM
  9. dpham00's Avatar
    Ah you used the stock app... The way you originally said it made it sound like you didn't need an app at all.
    08-19-2017 12:01 AM
  10. Aljean Thein's Avatar
    Yah that was my bad. Should've phrased it better.
    08-19-2017 12:07 AM
  11. JohnnyB6's Avatar
    on the same phone model the FM radio built in app works just fine... make sure it's fully updated, if the same issue occurs try to do a hard reset...
    12-25-2017 06:09 PM
  12. EchoZero's Avatar
    This is a well known bug. Just disable the "Say Ok Google anytime" under Voice Match and voilà, the radio is working again.
    Please report this issue to Huawei support because they are not taking this issue seriously. Thank you.
    Mags18765 likes this.
    12-29-2017 09:31 AM
  13. Mags18765's Avatar
    Thank you EchoZero that was exactly it! The second I turned "say ok Google anytime" off, the radio started playing.
    How can I report it as an issue to the right people? I'm on a Huawei P10 lite also.
    01-07-2018 01:18 PM
  1. Hello from 2nd wine production country
    By Raymon Vidil in forum New to the Forums? Introduce Yourself Here!
    Last Post: 08-30-2017, 04:51 PM
  2. Replies: 2
    Last Post: 08-16-2017, 08:54 AM
  3. Replies: 1
    Last Post: 08-16-2017, 08:51 AM
  4. Replies: 1
    Last Post: 08-16-2017, 08:42 AM
  5. How to disable the Charging Status (%) screen on my Galaxy S5
    By AC Question in forum Samsung Galaxy S5
    Last Post: 08-16-2017, 08:21 AM
