1. Ayhan Cetin's Avatar
    I bought this Huawei P10 and I was very happy and now it's not working.... The phone uses Google even if I delete it there are a menu named Gioglo. The main problem I have is the battery I lose life important battery when my phone is turned off. I tried everything but only ultra power saving mode works but I keep forgetting where it is.. And I downloaded createanyshortcup app but it doesnt work it's not possible make a goddamn ups shortcut. This phone should be able to switch over to ultra power saving mode when I turn it off!!
    Ps. Every time I turn on the phone I need to add Chrome browser to the menu then I can log on the Internet. This is of course while it's in UPSM
    Update. It was Chrome all the time. This phone only works with Chrome dev.. 100% better and it doesn't drain the battery when the phone is turned off..
    10-23-2017 06:05 AM
  2. Djlarocca's Avatar
    Yeah, chrome can be a massive battery hog. I always try to use a 3rd party web browser.
    10-23-2017 10:27 PM
  3. Ayhan Cetin's Avatar
    I tried several browsers and they aren't much better. Chrome dev 'only' use 29% as ment to if I'm not wrong and if it has a shortcut during ultra power saving mode my battery drains 5% or so during a night but I read someone only loose 1 or 2%
    10-24-2017 12:25 AM
  4. Djlarocca's Avatar
    If you go into your phone manager setting you can set up a few shortcuts (including battery) on your home screen. There's also a toggle to ultra battery saver in the pull down tool bar.
    Attached Thumbnails No shortcut for Ultra power saving mode-screenshot_20171024-135803.jpg   No shortcut for Ultra power saving mode-screenshot_20171024-135955.jpg
    10-24-2017 01:05 PM
  5. Ayhan Cetin's Avatar
    I have a P10 Lite no menus like yours on this phone.
    10-25-2017 10:28 AM
  6. Ayhan Cetin's Avatar
    Ups.. Sorry I found the ultra battery save tab from the pull down menu just didn't click on everything but I can't find the shortcuts menu
    10-25-2017 10:35 AM
  7. Ayhan Cetin's Avatar
    I'm using Deep sleep battery saver now. When screen is turned off the phone is in ultra power saving mode
    10-25-2017 11:25 AM
  8. Ayhan Cetin's Avatar
    And it also charges the phone fast. This is good. I don't understand why mobile companies don't think of things like these
    10-25-2017 11:30 AM
  9. Djlarocca's Avatar
    Glad it's working better for you. And the shortcut is in the phone manager app if you ever need it.
    10-25-2017 12:25 PM
  10. Ayhan Cetin's Avatar
    Thanks for your help. I discovered something fun. The phone charges 12% in 8 minutes and for a full charge that's 66.6 minutes..
    10-26-2017 06:10 AM
  11. Djlarocca's Avatar
    Yeah, Huawei knows how to charge a phone fast! I think it does slow down a bit once you get past 90%. Something about starting the cool down process .
    10-26-2017 07:22 AM
  12. TheVajayna's Avatar
    What if I want to use only the Power saving mode from notification bar, and not Ultra saving? Just by one click. I have tried everything. I have been downloading battery widgets and shortcuts makers for days, yet none of them is able to turn on/off power saving mode from settings.
    Any Ideas/tricks? I am bored of pulling down notifications, long press ultra battery and then choose. I want a simple one click button.
    06-12-2019 08:33 AM
  1. Update started for OREO
    By xplod566 in forum Sony Xperia XZ Premium
    Last Post: 11-03-2017, 11:11 PM
  2. Oreo out for xz premium
    Last Post: 10-23-2017, 12:09 PM
  3. Replies: 1
    Last Post: 10-23-2017, 02:31 AM
