1. iwcham1979's Avatar
    Hi guys. I'm having problems with my P10. I have bought a second-hand P10, 6 months old and in mint condition. I removed the factory plastic film and put a tempered glass on. The next day I noticed that i see white digitizer lines and discoloration around the touched area even on light presses. I have removed the glass and after about 15 minutes without the display protector, the things returned to normal. I put this down to poor protector quality. I used it like that for 2 days, with no issues. Then, I decided to put a new plastic film to avoid accidental scratches. After only 10 minutes, to my surprise, I noticed the same distortions on the display. Upon googling for a bit, I learnt that my phone may be suffering from static electricity problem. Is this correct, and if so, do I RMA? The display distortions from the electricity are most noticable when you try to remove the plastic film looking at the display at the same time.... After the removal, the things seem to stabilize.... Any suggestions welcome. (if important, both the plastic film and the glass were no name products)
    12-15-2017 10:46 AM
  2. iwcham1979's Avatar
    One thing I Iforgot to mention, the phone is from an early batch and without an oleophpobic coating...
    12-15-2017 05:43 PM
  3. dpham00's Avatar
    I would try to rma it since you already tried to use two screen protectors with the same problem.
    Not sure if they will rma it though being that you aren't the original owner but didn't hurt to try
    12-17-2017 01:45 AM
  4. iwcham1979's Avatar
    Ty for your reply. Rma will not be the problem. I will try with the more expensive screen protector first. It occured to me that the cheap ones might not be anti-static. Also, the person who put the glass on didnt use the anti-static wipe, only a micro-fiber cloth... If i Rma i will pray that the tech person not remove the glass...
    12-17-2017 02:34 AM
  5. dpham00's Avatar
    In my experience, I have used cheap plastic and glass screen protectors and never experienced the that you are having, although I don't have this phone, so can't say in this specific case. Worth a shot to try a better one for sure, just don't think it will make a difference.
    12-17-2017 12:38 PM
  6. iwcham1979's Avatar
    Ive been asking around.. The problem sems to be the absence of the oleophobic coating, which results in the build up of static electricity... Only the early p10 models came without this coating.... The phone has gorilla glass 5 so I decided to keep it in the original folder case without glasses, films and stuff....
    12-19-2017 10:03 AM
  7. dpham00's Avatar
    It is pretty inexcusable for a phone like the p10 not to have an oleophobic coating
    12-19-2017 06:24 PM
  8. iwcham1979's Avatar
    Well, problem even without the protection, so RMA time....
    12-20-2017 03:41 PM
  9. dpham00's Avatar
    That sucks but hopefully you will get it fixed soon
    12-20-2017 06:26 PM
  1. Huawei P10 lite - Oreo update ?
    By JohnnyB6 in forum Android 8.0 Oreo
    Last Post: 03-02-2018, 09:54 AM
  2. Problems with screen flickering
    Last Post: 12-15-2017, 12:09 PM
  3. Samsung S7 problem - phone dials wrong number
    By Android Central Question in forum Samsung Galaxy S7
    Last Post: 12-15-2017, 11:35 AM
  4. Samsung A7 2017 Outlook Problem
    Last Post: 12-15-2017, 05:43 AM
  5. Samsung S7 problem - phone dials wrong number
    Last Post: 12-15-2017, 04:13 AM
