I am trying to find safe way to root my HUAWEI P10 LITE. It has nougat 7.0. Everyone suggest TWRP, but it seems very complicated. Every one click method is virus or adware. So what should I do?
Printable View
TWRP and SuperSU. It's not complicated at all if you follow the instructions, and it gives you the ability to do a very simple total backup (it takes a long time, but that's computer time - it takes you a minute), and it allows you to install a lot of different ROMs.
