    Hi, I have a new Huawei p10 plus and have naturally been babying it and worrying about any little thing that sounds like a hardware problem, recently I discovered the camera rattle that happens when I tap the camera. This sound also happens when I put my phone down. I've looked at online posts and they have all led me to believe that the rattle is the focus mechanism and the sound should go away when I open the camera app. My rattle does not go away when I open the camera app and I am scared that there might be loose parts or something in my phone. My camera still works fine and I haven't noticed any focusing problems but I am still afraid that there might be fine internal hardware problems.
    12-22-2017 05:04 AM
  2. dpham00's Avatar
    I would go ahead and contact Huawei for a warranty replacement.
    12-22-2017 10:35 PM
  3. Maciej Glinka's Avatar
    Hard to rec this but . Try to set volume max . I think you say anout this . I think is from vibration module?
    https://drive.google.com/file/d/1BXM...ew?usp=sharing
    12-23-2017 02:50 PM
  1. How to disable Camera Importer on Samsung Galaxy S3 Tab
    Last Post: 12-26-2017, 05:46 AM
  2. Replies: 1
    Last Post: 12-22-2017, 06:16 AM
  3. LG Nexus 5 Camera and Torch Not Working
    Last Post: 12-22-2017, 06:10 AM
  4. Replies: 1
    Last Post: 12-22-2017, 03:33 AM
  5. This is a good example of speech to text Samsung S8 plus
    Last Post: 12-21-2017, 03:58 PM
