    Hi everyone! i have a problem. My P10 Plus become slower when the battery is drained to 59% on Oreo 8.0.0
    The same thing happen on Nougat Android 7.0.0 but it was at 20% remaning battery. But 59% is just not acceptable. i just made a guide to root p10 plus on 8.0.0 SO im not too bad in computer stuff, YES all battery management is disable on my phone. I notice the problem because RETROARCH emulator become unplayable like 10% speed when remaining battery is at 59% on Oreo, even Nes emulator. So i have to charge my phone everytime the battery come to 59%, its not acceptable. i checked all p10 plus option and i found nothing. im rooted so i even try with busybox installed and device control or kernel control and i changed some options, i even try Performance governor without succeed. i forgot to say, that even on Oreo If the battery is drained to 20% i cant play any 3D android game anymore, like Riptide GP2, because at 20% the game become ultra slow and skip frames a lot, its unplayable at all. i can live with the 20% battery problem i guess.. but the 59% battery remaning problem that cause slow down in retroarch is not acceptable, phone is more sluggish too at 59%. But only at 20% that 3D games become sluggish. Please let me know if you have a idea. thanks so much.
    05-05-2018 03:43 AM
  2. belodion's Avatar
    Would you like me to move this to the P10 Plus forum?
    05-05-2018 07:05 AM
  3. renejr905's Avatar
    yes, thank you
    05-05-2018 10:51 AM
  4. belodion's Avatar
    Okay, and welcome as a new member.
    05-05-2018 02:39 PM
  1. Cant connect my onlinw games😑
    Last Post: 05-07-2018, 04:28 AM
  2. how can i turn off the usb storage on my camera app, my phone is samsung j3prime
    Last Post: 05-05-2018, 04:18 PM
  3. On my LG phone how do I access my Clip Tray or saved box
    Last Post: 05-05-2018, 03:08 PM
  4. Pleas help me to reset my backup password🙏
    Last Post: 05-05-2018, 03:02 PM
