1. Marcin Pyrka's Avatar
    Hi.
    I dipped in water H P10.
    I tried to go as fast as possible, but it turned out that the backlight did not work.
    The image on the screen is displayed correctly. The other functions work well.
    Is it the fault of the motherboard or the screen? How to check?
    BR,
    Marcin
    06-22-2018 03:10 AM
  1. P10 lite_phone bent
    By fangovk in forum Huawei P10 & P10 Plus
    Last Post: 06-24-2018, 12:27 AM
  2. Why does Google Play Store not list an app that's installed on my device?
    Last Post: 06-23-2018, 05:41 AM
  3. Replies: 1
    Last Post: 06-22-2018, 04:08 AM
  4. File is not update when connected to MacBook using Android File Transfer
    Last Post: 06-21-2018, 10:56 PM
