1. neil74's Avatar
    Wondering if the AOD on the P20 pro is improved at all vs. the mate? Mainly if 3rd party apps maybe now show?
    04-07-2018 02:52 PM
  2. orangecroc's Avatar
    I haven't seen any showing, but I only found the setting to turn it on a few hours ago.
    neil74 likes this.
    04-07-2018 03:41 PM
  3. Aneres11's Avatar
    They don't show unfortunately.
    Just the Huawei apps - phone calls etc.
    Pretty rubbish really. Seems odd that they don't give you the choice, at the least.
    04-07-2018 04:53 PM
  4. dov1978's Avatar
    I'm still hoping they add 3rd party app support with an update. Samsung did the same when they only had stock app support for Always On Display with the S7 to begin with.
    Saying that, Huawei have being using their Always On Display this way since the Mate 9 Pro and don't seem in a rush to change it anytime soon.
    Weirdly Google Play Music is a 3rd party app that I've noticed also shows 'Now Playing' information on the Always On Display and not just with the Huawei Music App.
    04-07-2018 05:16 PM
  5. neil74's Avatar
    It does (on the M10 pro) make the AOD pretty pointless IMO. I am only getting sms and phone calls, the stock email app does not even work.
    Is worrying that they do not seem in a rush to fix and maybe it is buried in the settings and hard to find for a reason.
    Aneres11 likes this.
    04-08-2018 04:11 AM
  6. CrimsonRonin's Avatar
    How is the AOD on this? Any burn in?
    11-16-2018 06:48 AM
  7. Lucy Davies's Avatar
    I heard the AOD won't burn in as it moves up & down the screen to avoid burn in.
    11-16-2018 02:17 PM
  8. JZ VR's Avatar
    No it moves around after a while.
    11-27-2018 04:05 AM
  1. p20 being ignored?
    By Tom Gleeson in forum Huawei P20 & P20 Pro
    Last Post: 04-11-2018, 07:32 PM
  2. cant unlock zte majesty pro
    Last Post: 04-06-2018, 11:21 PM
  3. How to remove items from the AOD?
    By gotdurt in forum Samsung Galaxy S8 & S8+
    Last Post: 04-05-2018, 10:27 AM
  4. Sms go pro and Samsung s3 problem
    Last Post: 04-04-2018, 10:03 PM
  5. S9 face widgets not working on AOD
    Last Post: 04-04-2018, 10:01 AM
