1. csteele100's Avatar
    Got my p20 pro and loving it. However when I receive texts the phone vibrates but plays no SMS notification sound. Been through all menus (I think) and can't seem to correct the problem. Anyone else run into this???
    04-11-2018 02:12 PM
  2. inffy's Avatar
    Just to make sure,
    Open the Messaging app, click the 3 dots at the bottom, settings, ringtones and vibration, notification tone, make sure the notification sound you want is selected there
    There is no such setting on the P20 Pro. P20 uses the Android messages client and Huawei has done something that has disabled the ability to set an own notification sound for SMS messages. ONly place to change it is in the Settings - Sounds
  3. orangecroc's Avatar
    What sound profile do you have selected?
    And can you show a screenshot of your sound settings page to give us a better idea of what options you have selected.
    pkcable likes this.
    04-11-2018 03:33 PM
  4. pkcable's Avatar
    You don't have Do Not Disturb mode on, do you?
    04-11-2018 03:37 PM
  5. csteele100's Avatar
    Attached screenshots of both sound setting menu and message setting menu. Owned p10 and p9 previously band never had this issue. Don't know if I'm missing something obvious!
    Attached Thumbnails Huawei p20 pro No Sms sound!-screenshot_20180411-224406.jpg   Huawei p20 pro No Sms sound!-screenshot_20180411-224343.jpg
    04-11-2018 05:47 PM
  6. dov1978's Avatar
    Just to make sure,
    04-11-2018 06:22 PM
  7. inffy's Avatar
    Just to make sure,
    04-12-2018 04:42 AM
  8. orangecroc's Avatar
    Which profile is selected in the notification shade quick menu?
    04-12-2018 05:12 AM
  9. dov1978's Avatar
    That's weird. I'm using the same app albeit on my Mate 10 Pro and I can change the tone within the app settings
    04-12-2018 05:50 AM
  10. orangecroc's Avatar
    Is your mate 10 on 8.1 or still on 8.0? Maybe that's where the change happened?
    04-12-2018 05:59 AM
  11. inffy's Avatar
    That's the thing, it works with my Mate 10 Pro but not on my review unit P20 Pro :P
    And it actually doesn't work in other sms app either, just tried Pulse and nope, can't change the notification sound.
    04-12-2018 06:00 AM
  12. dov1978's Avatar
    Maybe something they've changed in 8.1 from 8.0?
    04-12-2018 06:47 AM
  13. inffy's Avatar
    I guess so. Shame that they have to tinker with everything. Generally the notification settings are also a total mess. You have two different places to set notification settings and only one of them is the native Android 8.1 Oreo settings.
    These are the things that make me hate every Huawei phone so much
    04-12-2018 07:44 AM
  14. Stephen Wardle's Avatar
    Hi you still stuck with this?
    04-25-2018 02:44 PM
  15. pkcable's Avatar
    Unfortunately this appears to be the best solution, IF someone finds a better one let me know. In the meantime this one gets marked as the answer.
    04-26-2018 11:31 AM
  16. fonejacker77's Avatar
    Use Material Messaging from the play store (it's free). Can customise the tone in that (and it has loads of other customisable features too).
    09-09-2018 11:32 AM
  1. No souund even after rebooting!
    By thanosisking in forum LG G4
    Last Post: 04-12-2018, 02:18 PM
  2. P20 pro No sound on receving sms
    By Android Central Question in forum Huawei P20 & P20 Pro
    Last Post: 04-11-2018, 03:35 PM
  3. P20 pro No sound on receving sms
    Last Post: 04-11-2018, 01:07 PM
  4. How do I set a custom SMS tone for a single contact?
    Last Post: 04-11-2018, 07:50 AM
  5. Can i leave my huawei mate 10 pro charging over night? Is it bad for the phone?
    Last Post: 04-10-2018, 05:07 PM
