1. iain h1's Avatar
    Hi guys. Does anyone know how to keep the beauty mode left on permanent unless I untick it?
    Since updating the phone yesterday it seems like the beauty mode doesn't stay on every time I come to video or take a picture.
    05-31-2018 02:46 PM
  2. isko.rado's Avatar
    Which version did you use?
    05-31-2018 02:48 PM
  3. iain h1's Avatar
    8.1.0
    Please tell me there's a way I can keep it on permanent ☺️
    05-31-2018 03:18 PM
  4. isko.rado's Avatar
    8.1.0
    I think whic Huawei version 107 or 110 or...?
    I read that on last 120 and 128 update they fix it
    05-31-2018 03:29 PM
  5. iain h1's Avatar
    ☹️☹️☹️ I thought it was something simple I could change in the settings as well to keep it permanently on. ☹️
    05-31-2018 03:35 PM
  6. odd1ne's Avatar
    Doesn't portrait mode always shoot in beauty mode?
    05-31-2018 05:56 PM
  7. OLD_HATCH's Avatar
    I think if you drop the resolution down one step from the highest it's enabled by default even when off.
    I think it's something to do with image stabilization or having a buffer of something.
    kind of annoying really. If I turn it off it should stay off.
    05-31-2018 07:45 PM
  8. Jadaress1's Avatar
    Lol beauty mode makes the skin look like clay.
    06-01-2018 08:02 AM
  9. doohsun's Avatar
    ya especially the selfie mode I spoke with the Huawei rep it's a joke they told me clear cache I was like that has nothing to do with that. They need to have option to literally turn off beauty mode not set for 0 it doesn't do anything. Give the user the option to turn it on or off. Asides from that I really enjoy the camera. Hopefully new updates that will correct this and add more AI or pro filters.
    06-01-2018 08:37 AM
  10. Jadaress1's Avatar
    Yeh i second that. Hopefully they'll listen. Took a picture of my daughter, we were both laughing at the results, think it was on the default setting of 5. Turned it to 0 its better than it was but yeh i just want natural portraits. So we really should have that option.
    06-01-2018 08:48 AM
  1. How do I delete photos from facebook using...
    By shabenz44 in forum Android Apps
    Last Post: 06-28-2018, 06:40 AM
  2. How to stop home123 add browser
    Last Post: 06-04-2018, 03:54 PM
  3. Note 4 to 8 screen
    By dmorgan924 in forum Samsung Galaxy Note 8
    Last Post: 06-01-2018, 05:10 PM
  4. Replies: 2
    Last Post: 05-31-2018, 04:09 PM
  5. How do I delete photos from facebook using...
    By shabenz44 in forum Ask a Question
    Last Post: 05-31-2018, 12:58 PM
