1. jfriedrich's Avatar
    I had a system update 2 days ago now, and since that update my alarms will not go off when I have Do Not Disturb enabled anymore. Does anyone have a workaround or fix for this? Thanks!
    06-22-2018 10:42 AM
  2. mimimichow's Avatar
    So thats what has caused me to be late for work the last 2 days in a row! Could not for the life of me work out why my alarm was activating but not playing any sound/vibrating
    06-28-2018 04:13 AM
  3. odd1ne's Avatar
    If you go into do not disturb in the options then go onto advanced options you can set what can disturb it so you can have it that alarms can disturb it
    06-29-2018 10:46 AM
  1. Pairing 2 phones 1 watch
    By Android Central Question in forum Samsung Gear S3
    Last Post: 06-12-2019, 11:38 PM
  2. Has anybody found a good way to turn the Pixel 2 XL flashlight on when the screen is off?
    By Android Central Question in forum Google Pixel 2 & Pixel 2 XL
    Last Post: 01-23-2019, 11:33 PM
  3. Google's refurbished replacement phones, are they all that bad?!
    By dlalonde in forum Google Pixel & Pixel XL
    Last Post: 01-20-2019, 02:24 AM
  4. Replies: 1
    Last Post: 06-22-2018, 01:46 PM
  5. How do I assign ringtones to individual text messages?
    Last Post: 06-22-2018, 01:21 PM
