My sms sound wont change. If i try to change the sound it will just add the sound so both sound is playing when i get a sms. The sound name is: Alarm beep.
I had this problem. I just disabled private space. Apparently, when you receive an sms, it gets sent to your main space Messages app and the private space Messages app so you get notification sounds for both. You can disable it entirely or set the notification sound to silent in private space.
