    My sms sound wont change. If i try to change the sound it will just add the sound so both sound is playing when i get a sms. The sound name is: Alarm beep.
    What to do?
    06-26-2018 08:44 AM
  2. tamyslove1's Avatar
    I am also having the same issue. It is extremely annoying. How can I get rid of this damn beep?!
    07-22-2018 10:11 PM
  3. Chester Pelle's Avatar
    I had this problem. I just disabled private space. Apparently, when you receive an sms, it gets sent to your main space Messages app and the private space Messages app so you get notification sounds for both. You can disable it entirely or set the notification sound to silent in private space.
    08-04-2018 03:05 AM
  1. Replies: 1
    Last Post: 06-26-2018, 03:09 PM
  2. My J7 pro 2018 doesnt have sound on message notification.
    Last Post: 06-26-2018, 11:53 AM
  3. I did a reboot on my Huawei PSmart and now i can't find the default ringtones
    Last Post: 06-26-2018, 11:42 AM
  4. PLEASE HELP - No Notification Sound on Sky Bet
    Last Post: 06-26-2018, 11:32 AM
  5. A radio sounds keeps coming on my phone how do i stop it from coming back on
    Last Post: 06-26-2018, 10:31 AM
