1. torbjornhb's Avatar
    Hi.
    I've just got my P20 Pro. I know I can change some of the actions the home button does through "settings". But, is there an app that takes control over the home button and let me decide what it should do and not do?
    07-06-2018 05:45 AM
  2. Rukbat's Avatar
    Not completely, but a launcher like Nova Launcher gives you a lot more choices, including any app and most widgets.
    torbjornhb likes this.
    07-06-2018 01:41 PM
  3. torbjornhb's Avatar
    Thanks . I've downloaded nova and are trying it out now. It gives a lot of options, but I haven't found exactly what I'm looking for. Will continue to explore the app
    07-06-2018 02:38 PM
  4. andrew_ackley's Avatar
    Nova pro is worth it. I didn't really like the Huawei launcher
    07-08-2018 10:51 AM
  1. How to use SIM from Spain in Canadian Note 5?
    Last Post: 07-06-2018, 02:41 PM
  2. Can someone help me to remove a stubborn app from my screen?
    By Sonniebonnie in forum Android Apps
    Last Post: 07-06-2018, 01:22 PM
  3. Replies: 5
    Last Post: 07-06-2018, 09:33 AM
  4. My finger print options doesn't show in setting
    Last Post: 07-06-2018, 07:02 AM
