Save big + get 3 months free! Sign up for ExpressVPN today
    Hi! I've just bought a P20 lite and I can't manage to see the battery icon nor the bar itself in the upper side of the screen. I tried everything and nothing happened. Can anyone help me? Is there any bug in the operating system I have to fix or else?
    Thanks a lot!
    07-30-2018 04:07 AM
  2. SeanJamesWright's Avatar
    Thanks a lot!
    Hi, there.
    If you go into your settings and tap the Battery section then at the very bottom tap Battery percentage, it should give you the option from there. I've attached a couple screenshots, hope this helps. 👍🏻
    07-30-2018 06:38 PM
  1. how can i program winamp to run inorder of what i want next
    Last Post: 07-30-2018, 02:02 PM
  2. galaxy j5 2017 strange battery drain
    Last Post: 07-30-2018, 10:04 AM
  3. J7 after updated too much battery consumed
    Last Post: 07-30-2018, 04:47 AM
  4. What is the current software for att s9+?
    By sleepnclass in forum Samsung Galaxy S9 & S9+
    Last Post: 07-30-2018, 03:08 AM
  5. How do I add a NEW exercise to the base exercise list?
    Last Post: 07-30-2018, 01:36 AM
