1. chrisfoster1uk's Avatar
    Hi all,
    I have finally made the leap from iPhone to Android (yes I know you must all be very proud of me). I've gone with the Huawei P20 Pro, which by the way is excellent in my opinion.
    However, I do have a question that doesn't seem to have been raised in this forum before.
    On the iPhone when I got a text message through, the notification stated who the text was from (whether that be the name in my contacts or simply the number).
    On the Huawei however it just pops up stating I have a text.
    Is there any settings anywhere that allows me to amend what information is displayed within the notifications so I can mirror what happens on the iPhone?
    Regards,
    Chris
    07-31-2018 12:50 PM
  2. bryantpark's Avatar
    Try going to settings > apps & notifications > apps. Then choose the app and go to notifications. You'll then be given choices on what type of notifications you want and where you want it to appear. Hope this helps.
    08-05-2018 03:38 AM
  1. got my p20.... now I have to send it back
    By spantch101 in forum Huawei P20 & P20 Pro
    Last Post: 09-06-2018, 02:03 PM
  2. Replies: 1
    Last Post: 07-31-2018, 02:36 PM
  3. HOw do you disable annoying whatsapp notifications
    By ehioze in forum Samsung Galaxy S8 & S8+
    Last Post: 07-31-2018, 11:50 AM
  4. Replies: 0
    Last Post: 07-31-2018, 09:14 AM
  5. How to stop notification from lowering your music volume
    Last Post: 07-31-2018, 08:36 AM
